Throttle Position Sensor- TPS. How do i set it?
Old Oct 24, 2004 | 03:12 PM
wompwomp61's Avatar
Default Throttle Position Sensor- TPS. How do i set it?
alright i just got my tps in the mail..this is really the only website i've found for setting it http://www.integra.orcon.net.nz/tps. is this the correct way to set it? the motor is a sohc zc and i got the tps off ebay. just a honda one,it didnt specify.
thanks
Old Oct 24, 2004 | 03:23 PM
RCautoworks's Avatar
Default Re: Throttle Position Sensor- TPS. How do i set it? (wompwomp61)
Yep thats the correct way
Old Oct 24, 2004 | 03:33 PM
wompwomp61's Avatar
Default Re: Throttle Position Sensor- TPS. How do i set it? (90blackcrx)
ok thanks..do/should i remove the tb though? can i just take off the tps, put on the new one and set it?
Old Oct 24, 2004 | 03:46 PM
Unless the tps has already been removed, it will be held on by rivets. So remove the tb but before you go threw all this, go to the store and by some longer screws that will hold the tps on. Also by 2 nuts that will thread onto these longer screws. Cut off the top of the screw, and screw them into the tb, then put the nuts on. This way it will be easier to adjust the tps next time you have to. Also the old rivets will need to be notched so a screw driver can fit in there, use a hack saw or a dremel.
polything
23
Jul 27, 2012 08:23 AM
DCxMagus
May 3, 2007 06:45 AM
cazper8890
Mar 2, 2007 08:25 PM
hOndafienD 04
Aug 26, 2004 12:51 AM
CRX A4
Jun 14, 2003 09:43 AM
