Base timing recommendations
Old Oct 21, 2004 | 02:40 PM
Bigjussin's Avatar
Default Base timing recommendations
what would u guys recommend on an LSVtec with 11.7:1 comp ratio? its fine at idle...but starts to knock really bad at 2500 on up.....not a rod knock sound by any means....not 100% sure on base timing now..will know tomorrow, and its running a skunk2 p28 ecu, if that helps, car has older 93 octane in it...im gonna add some cheater in a bottle(octane booster) and run that gas out asap...the motor has very low miles on it as well
are the ignition tables in that ecu too steep to use with my car on pump gas?
TIA
Old Oct 21, 2004 | 03:45 PM
PyroProblem's Avatar
Default Re: Base timing recommendations (Bigjussin)
Id run a stock ecu if possible. Id suspect the ignition tables are too steep like you said...
Try setting your base timing to 14 degrees and see if the pinging goes away.If not retard it some more...
Im currently running a stock P28 on a 2.0L 12.5:1 engine and had to retard the distributor almost all the way so it wouldnt detonate at WOT in 4th or 5th gear...
Good luck and RETARD that ignition before you lose your ringlands
Old Oct 21, 2004 | 04:31 PM
Bigjussin's Avatar
Default Re: Base timing recommendations (PyroProblem)
thanks i might try a stock p72 tomorrow to see what happens....
skiracer8148
Jan 5, 2007 12:33 PM
See Are X
Aug 4, 2004 09:21 AM
91integraLSVTEC
Jan 3, 2004 05:48 PM
stupidfast
Aug 14, 2003 09:08 PM
macdaddy
Apr 30, 2002 07:56 AM
