Does this sound good for a B18C (JDM) price wise?
The guy across the street from me has a obd2 B18C he wants to sell me for $500
I just inspected the external parts of the motor and everything looks okay. I tured the crank puley and it felt fine. The only problem is that it is pretty much a head and block only. It has an IM and thats about it.
Here is the list of missing stuff:
Header
Alternator
Distributor
Plug wires
Water Pump
Timing belt
Throttle Body
A couple sensors on the back of teh IM (not too sure what they are)
Trans and flywheel
Power steering pump
Wiring harness
I pulled the Valve cover and everything looked OK. No marks on the cam lobes. No residue or anything.
Does this sound good so far?
I am going to pull the head nad look at it more thorough (sp.)
Header
Alternator
Distributor
Plug wires
Water Pump
Timing belt
Throttle Body
Trans and flywheel
Power steering pump
Wiring harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">black valve cover.</TD></TR></TABLE>
which proves nothing.... the intake manifold would be a big clue, but your best bet is to check the lettering on the head.
$500 sounds like a reasonable price for a compelte head and block in good condition. especially if you want to build it on your own.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">Sounds like a block + head deal to me. Any way to tell if it's a GSR or Type R?</TD></TR></TABLE>
If the block says B18c1 its a gsr if it says B18c5 its a type-r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote">
If the block says B18c1 its a gsr if it says B18c5 its a type-r</TD></TR></TABLE>
JDM motors do not have numbers after the C. It will read just B18C.
Well I just went to look at it again and its actually a 94 b18c. I read the little circles this time. Im still not sure if its a good deal yet.
Well, I finally bought the motor, and am happy with it. I tore apart the head and block, and everything looks great. The motor can't have but 40,xxx mile on it. I paid 500 bucks for pretty much a short block. Was this a good buy?
not tryin to be rude but quit worrying about if it was a good buy or not and be happy with it. it sounds like you made the move you wanted and it sound slike a good deal and you said everything looked good.
to you
to you
10kracer
17
Jun 24, 2006 12:22 PM
