GSR Front Brake Conversion
Old Oct 20, 2004 | 08:59 PM
Jdm93civic's Avatar
Default GSR Front Brake Conversion
Can anyone tell me what is exactly needed for the front GSr brake conversion...
just list the parts i would need please...and anything else that is recommed...I have the rear brakes right now but not the front...i have the gsr pop valve and master cyclinder....and also people tell me GSR and LS brakes are the same is that true>
Old Oct 20, 2004 | 09:03 PM
pdiggitydogg's Avatar
yes theyre the same...I can say that 1000 times and no one ever cares.
if you have anything other than an ex (Im asuming eg, from your avatar) you'll need ex knuckles, rotors for ex/integra, and the front calipers.
thats it...an integra mc/bb is recommended.
its straight bolt on
you couldve found this info by searching
Old Oct 20, 2004 | 09:21 PM
Jdm93civic's Avatar
yea i could have but every time i do i find like a 1000 page thread...but thanksfor the help meng...appreciate it....i have to use ex knuckles? or Gsr or ls knuckles?
Old Oct 20, 2004 | 09:37 PM
like I said
ALL integra brakes are the same, so the knuckles are also identical.
you can use integra knuckles, over ex, if you want, but they are taller and will throw off the camber
Old Oct 20, 2004 | 10:50 PM
GetawayInMoscow's Avatar
Default Re: (pdiggitydogg)
I thought the front brakes were the same size on coupes as tegs? Or is that only the EX?
Old Oct 20, 2004 | 10:59 PM
MrMike's Avatar
Default Re: (GetawayinMoscow)
use any knuckle that comes with 10.4 rotors. all integra, and 94-95 EX and SI
Old Oct 21, 2004 | 12:00 AM
si hatches have the same brakes as dx.
(ex 92-00 and si 99-00 have 10.4" = same as integra)
Only ABS civic has the same size calipers as integras
(again, how many times do I have to say it?? look at the link in my signature)
Old Oct 21, 2004 | 12:15 AM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayinMoscow &raquo;</TD></TR><TR><TD CLASS="quote">I thought the front brakes were the same size on coupes as tegs? Or is that only the EX?</TD></TR></TABLE>
the rotors are the same if you have the 10.2ish, but the calipers on civics are smaller then integras.
Heres the brake thread https://honda-tech.com/zerothread?id=152884
Old Oct 25, 2004 | 09:29 AM
boosted_dc2's Avatar
Default Re: (=GAMEOVER=)
a gsr brake booster bolts in but the MC doesnt. the lines are in different locations, at least on a 95 cx.
Landon
Old Oct 25, 2004 | 09:42 AM
hadehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">like I said
you can use integra knuckles, over ex, if you want, but they are taller and will throw off the camber</TD></TR></TABLE>
by how much? i have integra knuckles and i didnt notice any drastic camber change.. my camber in the front is about 1.30 because of my drop..
Old Oct 25, 2004 | 09:48 AM
hayabusa160's Avatar
Default Re: (hadehatch)
straight bolt on dont have the swap the brake lines out.
just need the knuckle really nothing else. unless you want to do the sway bar and stuff.
you can use a integra rs brake booster wich is a 15/16 and bolts right in.
or the older jdm type r brake boosters.
Old Oct 25, 2004 | 09:49 AM
jspresso's Avatar
ex fronts are 10.2 inches and are the exact thing to a integra wether you have n ls or gsr and the knuckles are also the same.,..
Old Oct 25, 2004 | 09:51 AM
jspresso's Avatar
Default Re: GSR Front Brake Conversion (Jdm93civic)
also if you have a dx the rotors are an inch smaller than the ex/integras
Old Oct 25, 2004 | 10:59 AM
Targa250R's Avatar
be professional
I don't know what anyone else is talking about because they've turned this thread into a confusing mess of misinformation and irrelevent garbage, but I do know all about Civic/Integra brake systems and I can answer your questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm93civic &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone tell me what is exactly needed for the front GSr brake conversion...
just list the parts i would need please...and anything else that is recommed...I have the rear brakes right now but not the front...i have the gsr pop valve and master cyclinder</TD></TR></TABLE>
For the front brakes:
To do it properly on an EJ2 ('92-95 Civic DX coupe), which is what I assume you have, you will need the Integra knuckles and everything attached to them (including calipers, caliper brackets, hubs, lines, and dust shields). Get the proportioning valve from the Integra.
To improve pedal feel, you may also want to get the master cylinder and booster from the Integra - but be aware that you will have to mess with lines if you use these (I believe one line has to be bent and reflared). Another option is to buy a '90-91 Civic EX 4dr. master cylinder, which will bolt right up to your existing Civic booster and work with your Civic lines as-is.
Buy new rotors and pads, especially if the Integra was sitting in a junkyard for a while. Do not buy garbage slotted or drilled (or both) rotors, just buy regular blank rotors. Buy pads that suit your needs (i.e. if you drive on the street, do not buy race pads unless you have a death wish). Buy a container of either DOT 3 or DOT 4 brake fluid, because you'll be bleeding the system (do not spill it on your paint). You will need a flare nut wrench to install the master cylinder.
You may need to have new ball joints pressed in as well if you mess them up during removal.
That's about all I can think of for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">people tell me GSR and LS brakes are the same is that true&gt; </TD></TR></TABLE>
Yes, they are exactly the same. All '94-01 Integras (except Type-R) use the same brakes. This includes RS, LS, SE, GS, and GSR.
Old Oct 28, 2004 | 08:07 AM
Jdm93civic's Avatar
thanks buddy you rule!
Old Oct 28, 2004 | 08:20 AM
EL Vap133's Avatar
Default Re: GSR Front Brake Conversion (Targa250R)
Targa is right!
Old Oct 28, 2004 | 08:22 AM
Ricey McRicerton's Avatar
Default Re: GSR Front Brake Conversion (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Targa is right! </TD></TR></TABLE>
As always.
Old Oct 28, 2004 | 09:56 AM
Jdm93civic's Avatar
yea man thanks guys for all your knowledge
Old Oct 28, 2004 | 10:56 AM
toEknEEg's Avatar
Default Re: (Jdm93civic)
if you need a how to, search for a the topic under my name
Old Oct 28, 2004 | 11:30 AM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: (toEknEEg)
so what if i had a 90 civic dx? could i use the barkes off of an EX? arent those bigger thant dx or SI ef's?
Old Oct 28, 2004 | 11:54 AM
93CivicSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">si hatches have the same brakes as dx.
(again, how many times do I have to say it?? look at the link in my signature)</TD></TR></TABLE>
Slightly wrong - 92-93 Civics had 9.5" brakes - 94-95 (when ABS was an option) had 10.2" (10.4?) brakes, how do I know, have a 93 Civic Si - factory 9.5" brakes went bye bye about two years ago....
Old Oct 28, 2004 | 12:38 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
To do it properly on an EJ2 ('92-95 Civic DX coupe), which is what I assume you have, you will need the Integra knuckles and everything attached to them (including calipers, caliper brackets, hubs, lines, and dust shields). </TD></TR></TABLE>
I used the stock CX rubber brake lines from my front integra brakes, but they're not bolted to the shock body (AGX's dont have provisions for them).
Old Oct 28, 2004 | 03:29 PM
Default Re: GSR Front Brake Conversion (dantastic)
gsr brake lines are identical to the civic ones i checked when i was doing mines and kicked myself in the *** for wasting so much time trying to get the gsr brake lines in when they were identical. the civic ones fit better for some reason.
but is cool to use newer lines wont hurt.
Old Oct 28, 2004 | 06:35 PM
Jdm93civic's Avatar
lol now that have a lot of things cleared up any one selling a front gsr conversion???????
Old Oct 28, 2004 | 07:11 PM
litterbox's Avatar
I am a (Trial User) Army
i got one
