How do I mic the crank?
Old Dec 18, 2001 | 02:54 PM
paulzy's Avatar
Default How do I mic the crank?
OK, here's the deal...MY eagle rods didn't fit both ends, so I had the machine shop resize both holes(big and small). Now, I remember somebody saying that eagle made their rods to utilize the factory honda #2 bearings on all of them...Now that they resized the big end, I'm gonna need to get different bearings...
How the hell do I mic the crank to find out what size main and rod bearings to get?
Old Dec 18, 2001 | 03:51 PM
BowSeR's Avatar
New User
Default Re: How do I mic the crank? (Slow_ass_4dr)
did u buy those rods on ben's special. either you got the wrong rods or they were just made wrong. i had a set of crowers do that to me when i got to 25lbs of TQ they were locked on so u should have sent them back to eagle
Old Dec 18, 2001 | 09:20 PM
paulzy's Avatar
Default Re: How do I mic the crank? (BowSeR)
yeah, I've tried that, but I lost my invoice from them...
Old Dec 20, 2001 | 03:16 PM
paulzy's Avatar
Old Dec 20, 2001 | 04:39 PM
C-speed's Avatar
You don't mic the crank to find out what bearing shells to get, you have to plastigauge them.
http://www.c-speedracing.com/howto/b.../bearings.html
You mic the crank journals so see if they are true.
http://www.c-speedracing.com/howto/endplay/endplay.html
enjoy.
Old Dec 20, 2001 | 05:09 PM
BowSeR's Avatar
New User
Default Re: How do I mic the crank? (G3-TEG)
for the rod and main bearings do i have to order B18C bearings or can i order B16 bearings instead.
Old Dec 20, 2001 | 07:42 PM
rainforest's Avatar
mic'ing the crank is micropolishing it wich takes out grooves in the crank and you can mic a honda crank because of the way they are made. you will just throw bearings all day.
Old Dec 20, 2001 | 08:00 PM
hensley's Avatar
Default Re: How do I mic the crank? (rainforest)
If you are using "stock" honda bearings the Honda "Helm" shop manual will list the journal diameter for the crankshaft and the bore diameter for the rod. This also applies to the piston pin and the pin hole in the rod. The crank journal and the piston pin can be miked with any good mike reading to .0001". The bores are usually measured with a dial bore gage, using a good honing oil a a lubricant for the bore gage. with out the lubricant the reading will be a few ten thousanths off.
This is really a job for a machine shop. Final fit-up is done using plastigage to measure the oil clearance between the crank and the bearing surface. When finally assembled the engine should turn over easily if the clearances are correct.
Old Dec 21, 2001 | 01:17 AM
BowSeR's Avatar
New User
mic'ing is not micropolishing, its using a micrometer
Old Dec 21, 2001 | 02:50 AM
rainforest's Avatar
man someone give me a big old karate chop for that one.
Old Dec 21, 2001 | 06:17 AM
rtype11's Avatar
where did they get polishing the journals from mic?? anyway you measure your journal diameters to determine what condition they are in and whether they are within service limit and to determine what size bearings to use - this is a part of blueprinting a motor, the stock bearing code is stamped into the bottom of the block where the oil pan meets the block. after micing you shuld hope that you can stick to the factory bearing codes. micropolishing is really more like doing an align hone on your crank that needs refurbishing, it really isnt a performance enhancer just bringing crank backinto specs. now baancing and lightening will bring you some gains. lightening the crank helps in a few ways a) less rotational mass (inertia) b) less vibrational distortion - people believe this will save your high revving motor and oil pump from stress failures like from extreme cavitation c) with reduced mass comes reduced surface area which leads to reduced windage loss - this is good for 5 -10hp on race motors. d) less aeration of oil e) less crankcase gases to evacuate from reduced surface area.
[Modified by rtype11, 7:19 AM 12/21/2001]
[Modified by rtype11, 7:23 AM 12/21/2001]
Old Dec 21, 2001 | 06:23 AM
rainforest's Avatar
Default Re: How do I mic the crank? (rtype11)
allright iam a dumbass i understand i did not look at the the post right i thoght he was talking about micropolishing for some reason.
Old Dec 21, 2001 | 02:19 PM
BowSeR's Avatar
New User
so no one knows what the eagle rods are machined to? i keep hearing #3 but i have not got a confermation on that yet.
Old Dec 21, 2001 | 05:43 PM
paulzy's Avatar
another fucked up thing about my crank is that the journals are scored from a couple spun bearings...It was too close to cut, so they had to weld it, then cut afterwards...I'm probably gonna be running Federal Mogul rings...
Old Dec 21, 2001 | 08:04 PM
Mista Bone's Avatar
D Tranny Guru
you heard right, D rods = #3.
Search button is not a option, a requirement.
Old Dec 21, 2001 | 11:48 PM
Suprdave's Avatar
Get a new crank man...Honda Bearings 'oWnZ JoO'
I personally wouldn't do a ton of machining on a crank, when you get get 'like new' or even new ones for a couple hundred.
Suprdave
Old Dec 22, 2001 | 10:17 AM
BowSeR's Avatar
New User
Default Re: How do I mic the crank? (Mista Bone)
so the D series rods are #3 but what about the B series ones are they #3 also
Old Dec 22, 2001 | 10:41 AM
Blown90hatcH's Avatar
enjoy.
You guys always have some great articles on there. Good job
[Modified by Blown90hatcH, 11:42 AM 12/22/2001]
r1de4life
Mar 26, 2008 02:57 PM
egb18c5
Dec 26, 2007 08:32 AM
Bc3
Dec 26, 2006 11:35 AM
2BFI
Feb 11, 2006 08:43 PM
mattjohnston
Dec 9, 2003 03:35 PM
