help: disassembly & reassembly of tial 38 mm?
Old Oct 20, 2004 | 06:26 AM
scartail's Avatar
Default help: disassembly & reassembly of tial 38 mm?
I recenty installed my system... and for some clearance issues, I had to clock the banjo fitting relative to the flange portion... I ended up disassembling the wastegate... I have now reassembled it, but wanted to know if I did it properly. In particular the seating of the diamphram.
I've got a boost leak some where and want to double check everything I did.
Does anyone have proper instructions available and would post them. I bought the wastegate used. So, I don't know what information came with it. I've googled it, and searched here, but came up dry.
Thanks alot.
Old Oct 20, 2004 | 08:45 AM
Flamenco-T's Avatar
Default Re: help: disassembly & reassembly of tial 38 mm? (scartail)
There's nothing too special really other than making sure that the diapghram is not pinched when you put the top hat back on.
stan
Old Oct 20, 2004 | 09:34 AM
scartail's Avatar
Default Re: help: disassembly & reassembly of tial 38 mm? (Flamenco-T)
I see. I should take it apart and make sure then. I thought there may be some special way of seating or something.
Thanks for the tip.
Old Oct 20, 2004 | 10:49 AM
PrettyLude's Avatar
becareful not to rip it
Old Oct 22, 2004 | 02:31 PM
scartail's Avatar
STAN, you are the MAN!!!
I took it back apart and it WAS pinched (two places)... The diaphragm is not torn... However... due to the clamping... there is a crease in the it... Is it still ok? I would imagine... after a couple hot cycles... it would straighten it itself out...
Edit: Would that be a source of my boost problems??? Not holding boost that is...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">There's nothing too special really other than making sure that the diapghram is not pinched when you put the top hat back on.
stan</TD></TR></TABLE>
Modified by scartail at 3:55 AM 10/23/2004
crazy_ls_90
Oct 2, 2008 05:28 PM
TunerShark
Feb 6, 2007 10:51 PM
turbotime
Sep 26, 2005 07:01 AM
BoostingSnail
Mar 11, 2003 08:37 AM
