Wastegate Flutter
Old Mar 10, 2003 | 05:05 PM
BoostingSnail's Avatar
Default Wastegate Flutter
I've searched and searched and didnt find anything....
I feel stupid askin this bc I feel that I should know and I dont....
So anyways, What exactly causes wastegate flutter??
I was trying to figure it out on my own and I thought that its just an external wastegate that open to the atmosphere not using a boost controller, just using the wastegate spring to control boost......HOW FAR OFF AM I ON THIS?
[Modified by BoostingSnail, 9:06 PM 3/10/2003]
Old Mar 11, 2003 | 01:50 AM
fiaz79's Avatar
Default Re: Wastegate Flutter (BoostingSnail)
hey my wastegate was fine til today and now its fluttering too.. ive even lost boost pressure as i cant feel the kick-back i usually get... so someone help on this one....
Old Mar 11, 2003 | 02:01 AM
MiraiZ's Avatar
Default Re: Wastegate Flutter (fiaz79)
Are we talking about the wastgate or the blow off valve?
Old Mar 11, 2003 | 07:43 AM
BUMP
Im not sure if it is the wastegate or not.....could be something else....but in general Im speaking about the flutter experienced when you let off the gas after accelerating
Old Mar 11, 2003 | 08:17 AM
b16ahybrid's Avatar
BUMP
That would be your bov not your wg.
Try hooking your bov to a stronger vacuum source. I had the same problem until i found a better vacuum source
Old Mar 11, 2003 | 08:37 AM
Finest's Avatar
Check all of your intercooler pipings and couplings. It might have slipped, causing some boost to leak out.
BTW, it's the BOV that's making the "fluttering" noise when you let off the throttle. Trust me, you'll know what an EXTERNAL WASTEGATE sounds like! *Like a pissed off semi truck barreling down the highway*
flangemastermike
Jun 13, 2007 04:46 AM
Black DC2
Feb 9, 2005 08:20 PM
60-1
Mar 18, 2004 11:30 PM
whagkangmakulet
Oct 1, 2001 11:34 AM
