Integra cluster in EG
Old Oct 19, 2004 | 11:43 PM
jdmhondamotive's Avatar
Default Integra cluster in EG
http://www.geocities.com/Area5....html
^--- i dont get this diagram, its not telling enough for me, can someone either explain it to me or find me another diagram?
Old Oct 20, 2004 | 12:09 AM
BlueIntegraBoy's Avatar
Default Re: Integra cluster in EG (jdmhondamotive)
Example #1:
Integra Pin B6 = Speedometer (Orange Color)
When you repin, put Civic Pin B2 (Yellow/Blue Color) into Integra Pin B6.
Example #2:
Integra Pin B7 = Hatch Open Indicator (Blue/Black or Green)
Depin Civic Pin A2 (Green) and repin into Integra Pin B7.
Using that diagram, work from the right to the left. There will be empty slots on the Integra plugs.
Old Oct 20, 2004 | 12:35 AM
Blind-Fashion's Avatar
I used that exact diagram, its fucked to all hell.. i had to go back and rewire about 50% of the wires (using the 2 manuals)
Old Oct 20, 2004 | 06:23 AM
92civicb18b1's Avatar
Try to get a real wiring diagram or like blindfashion said use the 2 manuals.
Old Oct 20, 2004 | 07:51 AM
a1320honda's Avatar
Default Re: (92civicb18b1)
this is what i used to do mine, hope it helps.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Old Oct 20, 2004 | 08:41 AM
jbs's Avatar
jbs
Default Re: (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">this is what i used to do mine, hope it helps.
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
This is a relatively good list. Double check what year your Integra cluster came from though. My fuel for the Integra ended up connecting to the seatbelt. Basically there "might" be minor differences but all in all it is complete list.
Old Oct 20, 2004 | 09:12 AM
beaterdriver's Avatar
Default Re: (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs &raquo;</TD></TR><TR><TD CLASS="quote">This is a relatively good list. Double check what year your Integra cluster came from though. My fuel for the Integra ended up connecting to the seatbelt. Basically there "might" be minor differences but all in all it is complete list.</TD></TR></TABLE>
what year was your cluster?
Old Oct 20, 2004 | 09:14 AM
splitime's Avatar
Default Re: (beaterdriver)
I used a 94 LS interior wiring harness and all I had to do was trim off 2 pins from the one plug that doesn't fit into the fuse box and the majority of the other stuff plugged right in. Had to tap for power for the hazards and still haven't bothered with figuring out the rear defroster... but everything else works.
Old Oct 20, 2004 | 01:14 PM
Default Re: (splitime)
I only had to wire an LS cluster into an EK, and I got the diagram from a link in one of the threads. The thing worked at first repin. So, I don't know if the information from the above link is correct.
Old Oct 20, 2004 | 08:06 PM
ummm im not sure but it has 4 pluggs
Old Oct 20, 2004 | 08:22 PM
Default Re: (jdmhondamotive)
how can i find out?
Old Oct 20, 2004 | 08:55 PM
untitledsn41's Avatar
http://patriot.net/~merritt/gauge.html
hope this makes it a little easier
Old Oct 21, 2004 | 07:49 AM
Braco11's Avatar
Default Re: (untitledsn41)
quick (and possibly dumb) question: Do you need all the plugs from the back of the teg cluster or just the 2 main (blue) plugs?
Old Oct 21, 2004 | 08:01 AM
im using the main 2, the 13 and 16. but i dont have srs or anything like that in my car
Old Oct 21, 2004 | 08:49 AM
Braco11's Avatar
not concerned about srs. but what else do the other ones control?
Old Oct 21, 2004 | 05:32 PM
8point6's Avatar
Default Re: (Braco11)
What is the correct way to depin the wire? Cut it, or just yank it out of the harness?
Old Oct 21, 2004 | 05:57 PM
SPOON_BeIgHtEeNsEe's Avatar
i have a already wired up civic/gsr cluster harness.... all i need is ur haness + cash.... lmk if ur interested
Old Oct 21, 2004 | 06:39 PM
8point6's Avatar
Default Re: Integra cluster in EG (SPOON_BeIgHtEeNsEe)
How much are you asking?
Old Oct 21, 2004 | 06:58 PM
On a manual transmission Integra cluster, there are two big blue plugs and a yellow plug (SRS). On the automatic transmission, there are three blue plugs (one for the gear indicator) and the yellow plug.
Old Oct 21, 2004 | 07:54 PM
esteps's Avatar
Default Re: (BlueIntegraBoy)
i recently finished the whole dash conversation in my hatch, i used the diagram posted above and it worked well for me, i must say tho that the dash conversation is not worth the hassle! just do the cluster!
Old Oct 21, 2004 | 08:01 PM
Default Re: (b16a93cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a93cx &raquo;</TD></TR><TR><TD CLASS="quote">i recently finished the whole dash conversation in my hatch, i used the diagram posted above and it worked well for me, i must say tho that the dash conversation is not worth the hassle! just do the cluster!</TD></TR></TABLE>
Post some pics in the appearance forum for future references. I know someone will ask if the swap is possible in the future.
Old Oct 22, 2004 | 08:54 AM
splitime's Avatar
You don't think so? The teg dash looks very nice in the 92-95s, and you get a real cupholder! Oh and you can use dual guage bezels in the cluster area... that was the reason i did my conversion
Old Oct 22, 2004 | 10:07 AM
Default Re: Integra cluster in EG (8point6)
make me an offer... i actually have the whole dash setup if ur interested
Old Nov 2, 2004 | 04:59 PM
. o 69 o .'s Avatar
is your harness a civic harness converted to accept all the integra plug-ins like hazzards, rear defrost, etc or is it an integra harness with civic fuse block plugs?
EG_Type R
Sep 2, 2004 05:52 PM
jdmcivicferio
18
Aug 20, 2004 07:26 AM
racecarpete
Dec 23, 2003 07:23 AM
jbs
Dec 5, 2003 09:12 AM
