Integra Cluster Wiring Help!
Hey guys, I need your help. I just installed a 99 GSR Cluster in my EG. I've done the research here and I am having problems with my fuel gauge. I followed the diagram below which was taken from my search here. I got my cluster with plugs. I do not have the #14 Yellow/White plug in my GSR harness. I do have one that is White/Blue in the #5 slot which is shown as empty in the diagram. After wiring everything this was the only one not accounted for so this is where I have connected my Yellow/White wire from my EG. I figured since the plug came with the cluster, the pins are all in the right position and repinning the wire from the #5 to the #14 slot will not solve the problem. Any suggestions?
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Re: (jbs)
Just for posterity, I believe the above wiring diagram is complete garbage.
I had to cut most of my wires and re-do it.
The mostly correct diagram can be found @
http://patriot.net/~merritt/gauge.html
If something doesn't seem right, you can just follow the tracings on the back of the GSR cluster and make sure the grounds are in the right place for your cluster.
When looking at the tracings, it is pretty easy to figure out where the wires should go.
I used the merritt diagram and when I started up the car the temp gauge didn't work and neither did the gas gauge and the tach was freaky and the both turn signal indicators pulsated every second.
I had to move the temp gauge pin, a ground pin on the fuel, and I think it was all set. The wiring is pretty easy, just don't blindly follow the wiring diagrams- make sure that they correspond to your specific cluster.
Ben
Ben
92cxgsr
03-14-2002 06:34 AM
