Crower Stage 2T Cams
So, what do you guys think about the Crower Stage 2 Cams made for Turbo? I talked to Crower today and they told me they produced the cams using a b18c Turbo. I read somewhere that the issue with power drop off at VTEC could be helped with a set of Cams. Any opinions?
Cam gears have helped some get back a little of their power, but I am talking about going strong after VTEC engages, that is where most have been dropping. It seems to me that in that situation the cam gears are more of a band-aid than a fix.
tuning FI honda's cam gears isn't like a bandaid at all. It's as much of a bandaid as someone advancing ignition timing to realize more power. I'd agree if one were to say tuning stock cams on FI applications is not as beneficial as dropping a set of turbo cams, but to say it is a bandaid is not correct. It helps alleviate overlap and will indefinitely do so; as indefinitely as you stay in VTEC.
I also was considering a pair of those same cams, but I have other issues to resolve before I try to break into 11s.
superdgsr
Mar 15, 2005 04:19 PM
russian_racer
Jun 6, 2003 01:26 AM
