Spark plug choice.....
I'm wondering which spark plug would be better....Denso Iridium, NGK iridium, or other? I drive a 99 civic coupe (D16y8).
Give me an oppinion on which would be better.
Search, and check the surveys. But in sum up, NGK Iridium is the BEST for your vehicle.
P.S. Those 4 ground plugs are all bling appeal. They are no better than a good NGK.
if its stock motor... i would just run stock plugs.... or a lil bit better then stock but ... i wouldn't bother running the iridiums or bosch platinums
(platinums blow in my opinion) but if NGKs are OEM standard... i would run those.. i havn't even looked to see whats sitting in my civic... bout ta hit 100k and i have a feeling they're the original plugs....
How much of a difference do you think it'll be if I do get a NGK iridium plugs over Denso iridium though? I just need oppinion on how much of difference it would make.
i have obx iridium
well no there not that good but really i don't feel a difference from my stock ones to these. I just needed new ones and these were cheap on ebay and i could tell people that there iridium, jdm y0 plugs.
I would go with OEM Honda which will be NGK
Buying anything else is a waste of money
The car at http://www.ericksracing.com/racecar.htm runs 9.9 Secs in the 1/4 Mile and puts out 300 WHP All Motor running stock ignition
So unless you plan to run faster then that go with OEM
