installing the aebs
Old Oct 19, 2004 | 02:45 PM
honda06si's Avatar
Default installing the aebs
ok i just got the aebs intake manifold and i am about to put it on...there are 4 small vacuum studs in the back...does it matter what small hose goes where? and 3 bigger studs? will i NEED to put silicon on the head with the new gasket???
Old Oct 19, 2004 | 02:52 PM
honda06si's Avatar
Default Re: installing the aebs (honda90si)
what is the FTIV??? this isnt on the new aebs so just take it off? im not even sure what it is or lookks like
any pics??
Old Oct 19, 2004 | 03:00 PM
johnzm's Avatar
Old Oct 19, 2004 | 03:10 PM
honda06si's Avatar
Default Re: installing the aebs (johnzm)
thanks for the pic but it doesnt answer my question
Old Oct 19, 2004 | 03:45 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote">what is the FTIV??? this isnt on the new aebs so just take it off? im not even sure what it is or lookks like
any pics??</TD></TR></TABLE>
Right below the throttle body and no you do not need it, it is ment to warm up your car.
Vaccume lines can go in any order you want or eliminate them, I only have one for the FPR.
Old Oct 19, 2004 | 03:51 PM
jaydmcrx's Avatar
brake booster, pvc valve, fpr, and i capped off the 4th one.
Old Oct 19, 2004 | 04:33 PM
DocSean's Avatar
Default Re: installing the aebs (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
Vaccume lines can go in any order you want or eliminate them, I only have one for the FPR.</TD></TR></TABLE>
Does your car idle like chit jamie? I got 2 disconneced in my rex and the thing idles like a cam'd V8 when it warms up
Old Oct 20, 2004 | 09:05 AM
kid-honda's Avatar
Default Re: installing the aebs (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">
Does your car idle like chit jamie? I got 2 disconneced in my rex and the thing idles like a cam'd V8 when it warms up </TD></TR></TABLE>
Runs perfect I am probly going to be in grand forks this weekend, wanna drive it and see for yourself
Old Oct 20, 2004 | 03:27 PM
TheHatchHog's Avatar
You have 1st Gen B16a, we have FITV ( fast idle thermo vlave) located on the actual manifold. That aebs manifold is made for 94 Del sol VTEC, and 99 SI civic. They have the FITV mounted right onto the actual throttlebody. SO there is no hole to mount the fitv on for you. Just leave it off and bypass the coolant lines. I used to have this same manifold. I know a lot of 1st Gen b16as have a problem with idleing really high like 2500 for a couple minutes untill it warms, even when you tap the gas it still doesnt drop. This is normal becuase of the fact that you only have 1 wire O2 sensor, and FITV. but once you take that FITV off, it will idle right where it should be roght off the bat. Just let it warm up a bit before you go out cruisin. The big line is for break power booster line. the other 2 or three vacume lines are for the vacume lines that were on the front of the manifold, AEBS moves them to the back so it looks very clean and "show Like" ? hOPE SOME OF THIS HELPS?
Old Oct 30, 2004 | 11:13 PM
OldSchoolSwap's Avatar
I just got a good deal on the AEBS mani and i was wondering how would you compare it to the skunk2 manifold?
Old Oct 31, 2004 | 03:48 PM
LoSt is BlaCk's Avatar
Default Re: installing the aebs (OldSchoolSwap)
do you have the 2nd gen fuel rail...if not have fun fabbing the sensor, and fpr to fit...also test fit it to make sure you don't have to remove any material from the flange...i just installed mine and with the 1st gen b16 in an ef there are a few things that can go wrong...make sure you have a dremel and some other misc. tools ready for fab work, good luck pm me if you have any questions about the fitment...aebs get's a for acting like ti would simply bolt on...the damn thing does feel better though. so
rookshot06
Mar 17, 2008 03:01 PM
importtuner07
Aug 10, 2006 10:07 AM
dc2guy
Jul 9, 2006 12:05 AM
Terrabomb
Jul 23, 2005 01:53 PM
RCautoworks
May 24, 2004 10:06 PM
