Easiest way to raise redline 1000 RPM on an LS?
Old Dec 18, 2001 | 08:04 AM
OneThirtyEight's Avatar
Default Easiest way to raise redline 1000 RPM on an LS?
I have an LS, its fully built it can easially take 8k rpms. What is the cheapest/easiest way to raise the redline another 1000rpm.
Old Dec 18, 2001 | 08:23 AM
rainforest's Avatar
Default Re: Easiest way to raise redline 1000 RPM on an LS? (97blackteg)
there is not really a cheap to be able to get it to reline higher. you will have to upgrade the moving parts of the motor first and that is not cheap and then that is the only way to have it reliable and have higher revs
Old Dec 18, 2001 | 08:26 AM
Default Re: Easiest way to raise redline 1000 RPM on an LS? (rainforest)
Ill say it again, all these parts HAVE been upgraded. The engine is fully rebuilt, everything is stronger, it can easially take 8000rpm, I need to find out the cheapest way to simply rasie the rev limiter.
Old Dec 18, 2001 | 08:44 AM
4doorRS5spd's Avatar
New User
I don't know how cheap it will be, but there are many companies that make chips and piggy back ECU's that will allow you to override the rev limiter.
I would recommend using a new standalone ECU though. Go to http://www.hondata.com
They have programs that will allow you to program your existing ECU to achieve the higher redline.
Also try http://www.jdmhondaparts.com
Old Dec 18, 2001 | 09:04 AM
sohc_boy's Avatar
i think gforce engineering can reprogram your ecu with a higher rev limit not sure how much it will cost though. i would think cheaper than hondata.
Old Dec 18, 2001 | 11:20 AM
Katman's Avatar
chipping/reprogramming comes to mind...
Old Dec 18, 2001 | 12:20 PM
Default Re: Easiest way to raise redline 1000 RPM on an LS? (Katman)
who does this, and what would it cost me?
Old Dec 18, 2001 | 12:29 PM
WAFFLES's Avatar
Katman does it
Old Dec 18, 2001 | 12:30 PM
Katman's Avatar
Default Re: Easiest way to raise redline 1000 RPM on an LS? (WAFFLES)
why yes..yes i do
email me privately 97...
1 thing, I cannot do OBD2 ECU's.
[Modified by Katman, 1:31 PM 12/18/2001]
Old Dec 18, 2001 | 12:34 PM
is there anywhere that can do a OBD 2 ECU? Im not trying to spend a lot to simply raise my rev limiter 1000rpm.
Old Dec 18, 2001 | 12:35 PM
One8Hatch's Avatar
New User
are you able to do obd0 ecus? i have a 91 ls ecu that i've been looking to get chip w/ better specs. thanks
Old Dec 18, 2001 | 12:37 PM
Katman's Avatar
Default Re: Easiest way to raise redline 1000 RPM on an LS? (One8Hatch)
yep..I can do those too.
email me privately and I'll send you additional info .
danke.
Old Dec 18, 2001 | 02:59 PM
civic_hb96's Avatar
doesnt MSD make an egnition that can adjust your rev limit???
Old Dec 18, 2001 | 03:11 PM
Default Re: Easiest way to raise redline 1000 RPM on an LS? (civic_hb96)
ya, but I dont know if it overrides the stock rev limiter.... anyone know the anwser to this?
Old Dec 18, 2001 | 04:42 PM
JCushing's Avatar
i dont think obd2 is reprogramable, thats why you need to convert to obd1.
Old Dec 18, 2001 | 05:06 PM
RedlinedVTEC's Avatar
What is with everyone wanting to rev to 10k? I just don't get it, so what if you're motor can rev that high, does it still make powr up there? In most cases you lose power that high.
Old Dec 18, 2001 | 09:30 PM
Default Re: Easiest way to raise redline 1000 RPM on an LS? (RedlinedVTEC)
10k LOL, I want to rev to 8k. I have an LS that is fully built up, it is begging me to rev higher.
94-integra-ls
Feb 19, 2006 04:07 PM
superbeastcrx
Sep 17, 2005 07:20 AM
abs0lutexer0
Aug 4, 2003 10:18 AM
Project_SOHC_EX
Aug 20, 2002 08:52 PM
98 Ek LsVtec
Oct 29, 2001 11:05 AM
