H22 Belt size
I just finished swapping my H22 into my 92 Si and the last thing i need to do before i fire it up is belts. I had to replace the crank pulley with an aftermarket one and i removed the AC. Can someone give me the belt sizes i need for Power steering and alternator? I searched the archives and found that the F22 w/o AC is the same size as the H22 without AC but will the smaller size crank pulley matter much or doesnt that have much effect on the belt size? Thanks for any input on this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sabbotage »</TD></TR><TR><TD CLASS="quote"> Can someone give me the belt sizes i need for Power steering and alternator? I searched the archives and found that the F22 w/o AC is the same size as the H22 without AC but will the smaller size crank pulley matter much or doesnt that have much effect on the belt size? Thanks for any input on this.</TD></TR></TABLE>
Which crank pulley are you using?
If it's one for an f22 or h23, it won't work with the
h22 alternator.
I can give you the part number for an h22a belt w/no ac
but you would have to use the h22a crank pulley 6rib>5rib
h22 alternator.
i kinda had to get a new crank pulley because the one on the engine swap was cracked, so i didnt have a choice for that matter. And the auto parts store is 45 minutes away from where the car is so i wanted to go there first, which is why i asked for any input
I think maybe ill try the F22 w/o AC belt and see if that works. I'm not sure what the crank pulley size is on an F22 but the stock H23 pulley was considerably bigger than the stock H22 pulley so i imagine the F22 crank pulley is big as well.
im using an H22 aftermarket crank pulley. My pullies on both of my PS pumps and alternators are both exactily the same, but the H23 stock crank pulley was just bigger than the stock H22 one. Both stock pulleys were cracked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sabbotage »</TD></TR><TR><TD CLASS="quote">im using an H22 aftermarket crank pulley. My pullies on both of my PS pumps and alternators are both exactily the same, but the H23 stock crank pulley was just bigger than the stock H22 one. Both stock pulleys were cracked
If you are using an h22 aftermarket crank pulley 6rib
and the h22 alternator 6 rib w/ no a/c
the napa part number is 25-060370
</TD></TR></TABLE>If you are using an h22 aftermarket crank pulley 6rib
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">
the napa part number is 25-060370</TD></TR></TABLE>
In my project car I use only the alternator. Apparently the car was non-AC and the belt I ended up using was 25-060365. The belt above is only 5mm longer so should work just as well.
Silvertc
Jun 15, 2008 06:12 AM
b20vtecv8killer
Aug 5, 2004 10:41 AM
