Tach Hookup in 93 cx
Old Oct 19, 2004 | 09:05 AM
Mprezme_STi's Avatar
Default Tach Hookup in 93 cx
I am lost trying to find a good place to splice in for the rpm pickup on an auto meter tach any suggestions would be great.
Old Oct 19, 2004 | 09:59 AM
hatchfreak92's Avatar
Default Re: Tach Hookup in 93 cx (Mprezme_STi)
there should be a plug that isn't pluged into anything that has a blue wire that is the same one coming from the distributor. it is on the oposite corner of the battery. it is a plug with a black rubber covering the end that is where i spliced mine
Old Oct 19, 2004 | 10:44 AM
XkjeldorX's Avatar
Default Re: Tach Hookup in 93 cx (hatchfreak92)
u dont really have to splice it, i just jammed the wire in there and then put the black cover over it again and works just fine, just a thought
Old Oct 19, 2004 | 12:30 PM
Default Re: Tach Hookup in 93 cx (XkjeldorX)
i have already tried a couple of places and i belive that was one of them but for all i know it could have been the wrong one also i tried tapping in straight off the distributor it gave me a signal but the gauge showed way off like 6k at an idle both of the wires are clipped and i tried this with 2 autometer brand gauges and it produced the same results ill poke around some more thanks
Old Oct 19, 2004 | 07:39 PM
BlueIntegraBoy's Avatar
Tap the green tach wire with the blue wire behind your cluster.
Old Oct 19, 2004 | 07:49 PM
=GAME='s Avatar
Default Re: Tach Hookup in 93 cx (BlueIntegraBoy)
or you could tap that wire into the blue wire on the driver side shock tower, right by the clutch master cylinder.
Old Oct 19, 2004 | 08:30 PM
1slow_dx's Avatar
i tapped mine straight through the distributor and is works fine.
4dooreg-k
11
Jun 23, 2006 12:50 PM
VTECsound
Jan 13, 2005 09:16 PM
YellowCRXSi
Jul 12, 2004 09:55 PM
CHRIS 1.8
May 31, 2003 05:52 PM
Freelance-GSR
Dec 11, 2002 01:18 AM
