Smoking ITR !!!
Old Oct 19, 2004 | 08:03 AM
iperez's Avatar
Default Smoking ITR !!!
Ok, here's the deal .. Lately I've noticed that my R will puff a lot of gray smoke under hard acceleration. There is no smoking while driving normally. I checked the compression and I have a steady 255psi on all 4 cylinders. My valve head is polished and ported (porting is significant), I have JUN3's and a JUN ECU which tops at 9500RPM. The car runs great but I really don't like the 2-stroke engine effect with the smoke .. What can I check ??
BTW: Seeing how the engine seems to be healthy it was suggested to me that I install a catch can because my compression and high revs may be sending oil back into the intake. I am installing the can this weekend to see if that helps.
HELP !!
Old Oct 19, 2004 | 08:31 AM
integrasi's Avatar
Default Re: Smoking ITR !!! (iperez)
go get your a/f ratio tuned..
Old Oct 19, 2004 | 10:02 AM
iperez's Avatar
Ok, but how would my a/f ratio cause the engine to smoke (burn oil) ??
Old Oct 19, 2004 | 10:12 AM
integrasi's Avatar
Default Re: (iperez)
long story short:
if your air and fuel mixture is not correct, you get smoke
Old Oct 19, 2004 | 10:17 AM
Bbasso's Avatar
Curious,, what oil are you using?
Old Oct 19, 2004 | 10:49 AM
Nishant's Avatar
Default Re: Smoking ITR !!! (Bbasso)
a/f ratio makes sense, isn't oil usual black smoke?
Old Oct 19, 2004 | 10:50 AM
iperez's Avatar
Mobil1 5-30
Old Oct 19, 2004 | 10:52 AM
DsITR's Avatar
It could be unburnt fuel.. do you have lots of carbon deposits on your back bumper/hatch?
still, checking the a/f ratio is a good idea
Old Oct 19, 2004 | 10:55 AM
iperez's Avatar
I thought black smoke meant rich condition (too much fuel) and gray smoke meant burned oil ..
Old Oct 19, 2004 | 11:44 AM
Bbasso's Avatar
See I was burning oil, Lots of oil until the motor blew....
Now I was watching the clouds coming from my exhaust as time went by. I noticed that oil when burned in small amounts leaves a blue smoke trail. But burning a **** load of oil or should I say not burning oil, lots of oil leaves a black cloud- looking like unburnt fuel.
but yeah check the A/F first... maybe the Joke man has a good idea
Old Oct 19, 2004 | 12:37 PM
integrasi's Avatar
Default Re: (Bbasso)
black smoke doesn't neccesary means your running rich. what can happen is, your motor is running lean that your ecu will start pouring fuel into the motor, which could cause running rich..
check your a/f ratio since your only getting dark smoke when your reving.
Old Oct 20, 2004 | 09:35 AM
Footwork's Avatar
let us know when you install you catch can ivan...im curious to see if it fixes the problem sir.
Old Oct 20, 2004 | 10:03 AM
ITRNoah's Avatar
Default Re: (integrasi)
I dought it is a/f
you are geting blow by from some where could be that you do need a catch can maybe the crank case presure gets up there and pushes it through a valve seal or somthing I think that is a good start. You could always do a leak down test. Just my 2 cents. Just remember the R in Type R stands for Repairable I know all about it and I sure most people in this forum do.
Old Oct 20, 2004 | 11:06 AM
iperez's Avatar
Amen to that !! hehe !! I too don't think the a/f ratio could be that much off.. I checked the air intake and it was clean of oil but the pcv tube was very oily.. could the oil be coming from there ??
Old Oct 20, 2004 | 11:23 AM
Philly_NBP_R's Avatar
valve seals?
Old Oct 20, 2004 | 11:57 AM
boosted maniac's Avatar
Default Re: (Philly_NBP_R)
you only usually get smoke from valve seals after your car idles for a while...prolly not that..
Old Oct 20, 2004 | 12:24 PM
totsie7944's Avatar
My ITR smokes a little bit when I take it to really high rpms like pretty much when vtec engages at 6700 rpm. But I also know for a fact that my car is running a little rich. I just don't have the time or money to get it re-dynoed right now. I just got it done about 2 weeks ago and it still isn't quite right.
Old Oct 20, 2004 | 06:54 PM
m R g S r's Avatar
Default Re: Smoking ITR !!! (integrasi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi &raquo;</TD></TR><TR><TD CLASS="quote">go get your a/f ratio tuned..</TD></TR></TABLE>
Alright, you don't get your a/f tuned. A tuner will play witht the fuel tables, and aim for a correct Air Fuel Ratio.
N/A 14:1
Boosted 12:1
Old Oct 21, 2004 | 02:06 AM
LilistFear's Avatar
just could be snoot. I get that crap all the time, everytime I get on the Yoko Yoko toll roads I hall it and blow out a small stead cloud of smoke around 7k to redline. I also got a fields vtec controller. But who knows, I thought it was normal thinking that when you just driving around all the snoot just sits there until it get blowen out... Just me imput.
Old Oct 21, 2004 | 04:07 AM
iperez's Avatar
Snoot ??
Old Oct 22, 2004 | 07:39 AM
Footwork's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">Snoot ??</TD></TR></TABLE>
soot perhaps lol.
mr2passat801
Aug 15, 2010 08:16 AM
azandford
Dec 20, 2009 02:48 PM
Redprelude98
30
Jul 21, 2009 01:21 PM
kornerk12
May 1, 2007 12:09 AM
ItzTw
Dec 16, 2003 09:15 PM
