How do I make a fuel cut off switch?
Old Oct 18, 2004 | 05:42 PM
jeffk182's Avatar
Default How do I make a fuel cut off switch?
Hey, I own a 00 SI and I want to make a fuel cut off switch. How do I make this and what materials would I need? I diagram or something would be nice. THanks.
Old Oct 18, 2004 | 05:46 PM
ej1 pilot's Avatar
Default Re: How do I make a fuel cut off switch? (jeffk182)
theres a DIY somewhere on here...search
Old Oct 18, 2004 | 05:47 PM
civictildeath's Avatar
i want to do the same to my civic. i plan to use a toggle switch on the fuel pump just find the the wires cut one splice a toggle into it (add more wir to reach desired location of switch) and vwala
Old Oct 18, 2004 | 05:58 PM
Luserkid's Avatar
http://www.courtlukens.com/cutoff_switch.htm
Please search next time
Old Oct 18, 2004 | 06:34 PM
pwrofdrm's Avatar
Default Re: How do I make a fuel cut off switch? (Luserkid)
DO NOT use the above directions...I made a topic a couple days ago search my recently created topics. Someone posted on there why it's wrong.
Old Oct 18, 2004 | 06:35 PM
Luserkid's Avatar
Default Re: How do I make a fuel cut off switch? (lax1185)
Why not? I used it and never have a problem. Worse thing that happend is the fuel pump fuse went out once. That was it.
What went wrong?
Ej1_coupe's Avatar
worked for me.. off to go read why it is wrong.
Old Oct 18, 2004 | 06:37 PM
Luserkid's Avatar
Default Re: How do I make a fuel cut off switch? (Ej1_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe &raquo;</TD></TR><TR><TD CLASS="quote">worked for me.. off to go read why it is wrong.</TD></TR></TABLE>
Link me please
Old Oct 18, 2004 | 06:40 PM
pwrofdrm's Avatar
lazy *************
https://honda-tech.com/zerothread?id=1017774
Old Oct 18, 2004 | 09:52 PM
jeffk182's Avatar
Hrmm...thanks for the the help guys
Old Oct 18, 2004 | 10:39 PM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1185 &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT use the above directions...I made a topic a couple days ago search my recently created topics. Someone posted on there why it's wrong. </TD></TR></TABLE>
the wire gauge he was using was too big so it drew too much current and caused it to melt
Old Oct 18, 2004 | 10:51 PM
LSvtechatch97's Avatar
Default Re: How do I make a fuel cut off switch? (egcoupe)
so what guage should we use? 16? 18?
Old Oct 18, 2004 | 11:27 PM
tianporn's Avatar
Default Re: How do I make a fuel cut off switch? (FUKuPAYme)
Bro run a relay to be safe.
Old Oct 19, 2004 | 12:42 AM
civtegra_hybrid's Avatar
don't do that **** to the fuel, every one and there momma does that ****. you need to run a switch to the ecu power. and I tryed that fuel pump **** and that **** sucks. it didn't work that good. I shut it off, and it ran for a min. and it died and then when I turned it back on it took for every to turn on. that **** was wack.
Old Oct 19, 2004 | 01:18 AM
AGENT 99's Avatar
Default Re: How do I make a fuel cut off switch? (civtegra_hybrid)
melting wires? Fuel tank? Ummm, okay how do you do the ecu on/off thing? That sounds safer.
Old Oct 19, 2004 | 04:12 AM
jay.dee.em1's Avatar
Default Re: How do I make a fuel cut off switch? (6gcivic)
heres a safe way to do it&gt;&gt;&gt; go inside the car on your front passenger side and remove the kickpanel underneath the glovebox by the door..this is where your ECU is.. there will be a whole lot of wires but you have to find a yellow wire with a green stripe..there will only be 1 of them..make sure its not a green wire with a yellow stripe..just cut the yellow wire with the green stripe and run new wire from each end of it...run this new wire to a regular on/off switch..1 wire to each end of the switch..mount the switch to your desired location and put your kickpanel back on&gt;&gt;its real easy
Old Oct 19, 2004 | 05:55 AM
gsrjeff's Avatar
Default Re: How do I make a fuel cut off switch? (jay.dee.em1)
what the hell does it matter if u do it up front or in the back? eather way does the same thing but if it melts which it proable wont but it would be under the dash.
i did it in the back under the seat fine no proablems for over 2 years. as far as the car still runing for like 1 min. the fuel has to burn all the way out.
Old Oct 19, 2004 | 06:14 AM
blaster834's Avatar
Covered So much search...
Old Oct 19, 2004 | 06:16 AM
BauleyCivic's Avatar
Risky Business
Default Re: (blaster834)
Just go to radio shack, buy some wire that is about the same size, and splice the yellow wire with the green stripe to a switch...thats it
GSR-TRBO-DA
Jul 10, 2007 06:46 AM
boosted_LS
Aug 8, 2005 03:31 PM
adictionbass
Audio / Security / Video
11
Jan 28, 2005 06:49 AM
kKdARIAN
16
Dec 16, 2002 09:06 AM
Lynx
May 16, 2002 05:17 PM
