need some advice with b16a2 power up
Old Oct 18, 2004 | 02:08 PM
fastsmurf04's Avatar
Default need some advice with b16a2 power up
which would be the better set up, jackson racing supercharger or turbo bolt on kit? if i do the turbo kit do i need to build the motor? ive heard the compression is to high i need some advice!! please help!!
Old Oct 18, 2004 | 02:11 PM
_gurusan_'s Avatar
Default Re: need some advice with b16a2 power up (fastsmurf04)
What are your goals?
The JRSC will give you great daily driving torque...gives power where the b16 has NONE whatsoever.....(below 3000)...but it has less peak HP....
You don't have to build your engine for a turbo...(again depending on your goals)....you just need to tune it well for it to be reliable...
The turbo will provide you with a LOT of peak HP and a lot of torque..but you will have some lag depending on which turbo you choose
Old Oct 18, 2004 | 02:12 PM
Default Re: need some advice with b16a2 power up (_gurusan_)
i just want something reliable, and something that is a sleeper, i only plan on using a t3/t4 but just some basic bolt on things.
Old Oct 18, 2004 | 02:17 PM
11psiTurboSI's Avatar
Do it right the first time.... TURBO
Old Oct 18, 2004 | 02:39 PM
Default Re: need some advice with b16a2 power up (9psiTurboSI)
come on guys help!!! im looking!!
GEN2 LS
Aug 29, 2012 02:51 PM
Midwest_Ridaz
Oct 8, 2009 09:22 PM
1baddcivicsi
Oct 11, 2006 10:09 PM
Evil_Wizard
Jul 24, 2003 06:23 AM
LOwrestling2001
Nov 11, 2002 07:30 AM
