rods for b18c1 block with ls crank
Old Oct 18, 2004 | 09:13 AM
JBBNJ609's Avatar
Default rods for b18c1 block with ls crank
i have a b18c1 bored to 85 mill, its all motor and i want an ls crank to stroke it alittle bit
what rods would i use to keep my cr high ( around 12.5) but keep my rod ratio at close to 1.58 (or another good ratio for power and safe to high rev(around 9,500 rpms)
thanks
Old Oct 18, 2004 | 10:23 AM
93lsd's Avatar
Default Re: rods for b18c1 block with ls crank (jason bouchard)
use all ls stuff you will use ls rods with ls rod bearings and ls main bearings, you may have too tap closed the oil squirters because the crankk counter weights may hit them
Old Oct 18, 2004 | 10:50 AM
JBBNJ609's Avatar
Default Re: rods for b18c1 block with ls crank (93lsd)
well how can i safely spind to 9,500 ( or to when my cams are still makign power) with ls rods ??
im hearing that the oil squirters can be bent
Old Oct 18, 2004 | 10:56 AM
93lsd's Avatar
well mine is a 84 mm and the counter weights were hitting the actual 10mm bolt that holds the squiters and i and taking mine up too 9,000 with no problem using acl bearings.
Old Oct 18, 2004 | 11:41 AM
Boner_Ben's Avatar
LS rods
Old Oct 18, 2004 | 10:00 PM
JBBNJ609's Avatar
is there any crank i can use that will retain the oil squirters ??
is there any stroker kits that are for a 85 mm gsr that will have an 89 mm crank
i need to buy a crank, rods and pistons, it might be cheaper to buy a small stroker kit then to peice it
Old Oct 20, 2004 | 08:05 AM
JBBNJ609's Avatar
Default Re: rods for b18c1 block with ls crank (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">any true stroker kit wont be cheap they never are.. so u got a sleeved block now? pm me </TD></TR></TABLE>
hey jon, YGPM
super jdm yo
21
Jan 18, 2009 05:22 PM
jordan2305
Dec 11, 2007 04:47 PM
cornhusker
Oct 4, 2004 02:58 PM
svmnredracr
Sep 28, 2004 07:46 AM
WykidEH
Oct 18, 2001 11:34 AM
