my rev is set a 10k on a stock b16a2 its not that safe??
Old Oct 18, 2004 | 06:27 AM
gulftiresinc's Avatar
Default my rev is set a 10k on a stock b16a2 its not that safe??
my rev is set a 10k,vtec is also set at 4200 its on stock b16a2!!!
how safe is it?
its in a 00 si,with a header and test pipe obd1 !!
Old Oct 18, 2004 | 06:29 AM
accident prone's Avatar
Default Re: my rev is set a 10k on a stock b16a2 its not that safe?? (gulftiresinc)
im not a hundred percent sure so youll want more advice but personally i wouldnt bring it that high, id stay in the 8ks but thats me and i drive a dx so i stay below 7 as of right now, just advice id listen to some of the other members too though
Old Oct 18, 2004 | 06:34 AM
b18c1civic's Avatar
Default Re: my rev is set a 10k on a stock b16a2 its not that safe?? (accident prone)
ARE YOU SERIOUS?? dont take it up to 10,000, theres a reason the stock rev limiter is 8200, if you want to take it a little higher maybe 8500 but thats a game you shouldnt play... also setting your V-t4Ck so low doesnt help either, it will slow your car down, Vtec isnt working when it kicks in that low... keep it at 5200-5500 range...
Old Oct 18, 2004 | 06:38 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: my rev is set a 10k on a stock b16a2 its not that safe?? (b18c1civic)
Hell no it's not safe.
1. That engine won't make power past 8000rpm
2. The valvetrain isn't designed to take revs over 8200rpm
Do you need any more reasons why that ECU is a bad idea?
Old Oct 18, 2004 | 07:09 AM
JinDIESEL's Avatar
Default Re: my rev is set a 10k on a stock b16a2 its not that safe?? (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Hell no it's not safe.
Do you need any more reasons why that ECU is a bad idea?</TD></TR></TABLE>
period
Old Oct 18, 2004 | 07:11 AM
goforbroke's Avatar
MEAT PATTY
Why would you in the first place?
Stock honda fuel maps are only good to 9000rpm anyway so 10,000rpm=
Old Oct 18, 2004 | 07:14 AM
CivicSiR's Avatar
excatly, there is no point in doing that...no stock or nearly stock honda is gonna make power that high.
Old Oct 18, 2004 | 07:20 AM
H23AHybridEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1civic &raquo;</TD></TR><TR><TD CLASS="quote">ARE YOU SERIOUS?? dont take it up to 10,000, theres a reason the stock rev limiter is 8200, if you want to take it a little higher maybe 8500 but thats a game you shouldnt play... also setting your V-t4Ck so low doesnt help either, it will slow your car down, Vtec isnt working when it kicks in that low... keep it at 5200-5500 range...</TD></TR></TABLE>
My VTEC engagement point was optimized at 4400 However, that's not to say that yours will be...
Old Oct 18, 2004 | 07:27 AM
Design's Avatar
I never actually seen anyone run regularly above 9,000. I wouldn't consider taking it above the stock redline without reinforcement. Here's something to consider:
http://www.kingmotorsports.com...l=243
Hope that helps.
Old Oct 25, 2004 | 04:13 PM
Radyjr's Avatar
don't try to rev it that high, i have the same and the highest i reved was 9g, enless you got your head work to enable to go to 10g then that ok, but stock don't (say good night to the head, or even more piston through the block)....
Old Oct 25, 2004 | 05:01 PM
pwrofdrm's Avatar
Default Re: my rev is set a 10k on a stock b16a2 its not that safe?? (Radyjr)
Even 9k is too much. You're not a mechanical engineer with decades of experience, are you? What on earth makes you think that if it was good for your car to do that, Honda wouldn't have done it already?
Old Oct 25, 2004 | 05:37 PM
ABK's Avatar
ABK
Default Re: my rev is set a 10k on a stock b16a2 its not that safe?? (lax1185)
all I got to say. Valve float, no power making up there with stock motor. I don't think that honda's stock inginition is capable of working way up there, so you are prolly missfiring like a ****. You are lucky if you didn't spin a bearing yet or weaken your bottom end.
Don't do this unless you wonna throw a rod really bad.
Old Oct 25, 2004 | 05:40 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radyjr &raquo;</TD></TR><TR><TD CLASS="quote">don't try to rev it that high, i have the same and the highest i reved was 9g, enless you got your head work to enable to go to 10g then that ok, but stock don't (say good night to the head, or even more piston through the block)....</TD></TR></TABLE>
Dude even headwork won't let you rev that high without causing damage to the motor. you need to totaly rebuild the bottom end and it still won't be dependible at those rpms.
Old Oct 25, 2004 | 05:44 PM
Apocolipse269's Avatar
i hope by rev, you mean idle, and by 10k, you mean 1k. Your car will...well, if you keep ur engine at 10k, to speak in your terms, it go boom boom. So if you really meant idle at 1k, then that's safe, but make it lower, otherwise fix your car, cuz...again, it go boom boom
CheckMyFitment
Oct 14, 2013 07:17 AM
mozzandherb
Jun 19, 2006 08:20 AM
chicchocrider
Feb 6, 2006 11:19 AM
quicksol95
14
Apr 2, 2004 10:19 AM
b16a2EG6
Jul 27, 2003 10:58 PM
