Arias pistons in backwards?
Old Oct 17, 2004 | 02:43 PM
ogabudiah's Avatar
Default Arias pistons in backwards?
Ok i recently put a set of arias 9-1 CR pistons in my ls and i was confused about where the cut outs in the piston went, and finnaly decided that the cut out was there to unshroud the intake valve to let the air in easier, they dont need to be on the exhaust because the exhaust has pressure to force it out. then i saw this picture and was worried about it again, so look at it and tell whos right. not trying to convict him or anything just want to know if i did it right.
https://honda-tech.com/zerothread?id=1025251
Old Oct 17, 2004 | 05:23 PM
civictildeath's Avatar
Default Re: Arias pistons in backwards? (ogabudiah)
ok there should be some sort of mark usually an arrow that indicates the front of the motor
Old Oct 17, 2004 | 06:07 PM
ogabudiah's Avatar
Default Re: Arias pistons in backwards? (civictildeath)
Well i am talking about the cut out on the piston, the part that is missing on the top.
Old Oct 17, 2004 | 06:37 PM
Dr.c's Avatar
The easiest way to tell which is which is by the size of the vakve reliefs! The intake side has bigger reliefs!
boostedb20z
Feb 10, 2008 05:35 PM
12thstreetjunkman
May 1, 2006 07:07 PM
mrDFWmechanic
Nov 21, 2004 06:58 PM
turbohatch98
Jul 8, 2003 07:25 AM
senpai
May 15, 2003 03:18 PM
