LS/VTEC Help
Old Oct 17, 2004 | 11:36 AM
doubledeuce's Avatar
Default LS/VTEC Help
I am considering an LS/VTEC swap into my 90 crx si. I was curious if you can put the crankshaft out of a B16 into the block from a B18(A or B) since the B16 crank is zero balanced so I don't have to worry about high rev problems. Also would I have to use the rods/pistons from the B16 or could I put the B18 ones on that crank?
Thanks
-Caleb
Old Oct 17, 2004 | 12:29 PM
drdisco69's Avatar
Default Re: LS/VTEC Help (doubledeuce)
B18c block + CTR rods and pistons + B16 Crank = CTR block
Old Oct 17, 2004 | 12:36 PM
Default Re: LS/VTEC Help (drdisco69)
If I was to use a B18c block I wouldn't have to use the B16 crank since the B18c block is already VTEC and thus the crank would be zero balanced.
-Caleb
Old Oct 17, 2004 | 02:49 PM
rsbad454's Avatar
first of all...why the hell would you want a b16 crank if you are building a LS VTec? doesnt that kinda defeat the purpose? the B18 A and B are internally balanced as well, so you have no arguement there. The LS block is as good as the GSR block minus the squirters....
Old Oct 17, 2004 | 03:17 PM
Default Re: LS/VTEC Help (rsbad454)
Yes they are balanced, but not to as strict of standards as the VTEC blocks since they weren't meant to spin as fast. I do have an argument, I have heard of several cases that people have problems at higher rpm's(excess of 8,000)
-Caleb
Old Oct 17, 2004 | 04:03 PM
rsbad454's Avatar
Hello, any motor will spin if balanced properly.....I have been around racing motors my entire life, mainly domestics, but the same priciples hold true. There arent any strict standards that a V Tec crank is spun to, what is it? Id like to see. You can spin any motor no matter what the r/s ratio is, i do agree high speed balancing is a must with LS cranks. The cranks from B18's and B16's are made from the same material and balanced per weight of the combo.
s.cha
Jan 3, 2017 03:12 PM
turbob16ef
Dec 13, 2006 09:54 AM
CircuitFG
May 4, 2005 01:19 AM
Train
Mar 17, 2004 03:27 PM
g2teg
Apr 8, 2002 03:38 PM
