Headgasket
Old Dec 17, 2001 | 04:04 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Headgasket
Whats a good Headgasket to raise my compression with? I have a 95 gsr block and i was wanting to keep stock internals but raise the compression. I know the Mugen will raise it to i think 10.4.1. Is theres anything else that is better or that will raise the compression more? Will i have any clearance issues with a thin head gasket? Thanx...
Old Dec 18, 2001 | 12:42 AM
AJ PwR's Avatar
Default Re: Headgasket (Big Carbon)
Milling head is never a wise way to raise your compression. I will suggest you to replace the headgasket like Spoon or Mugen.
Old Dec 18, 2001 | 07:00 AM
Spade's Avatar
Keep the stock headgasket and get the head milled 30 over.......OR do it the right way and get higher compression pistons.
Old Dec 18, 2001 | 07:15 AM
WAFFLES's Avatar
Default Re: Headgasket (Spade)
People don't like the idea of milling the head, because it can later cause problems with cooling and after it's done, you can't replace that lost material. However, I think milling the head just slightly is okay, maybe 10. Just don't get crazy with it. The best, safest way of raising compression is a headgasket, like the one from Mugen, and pistons. Because of the shape of you combustion chamber in the gsr head, your compression will be higher than that of a b18c5 if you switch the r pistons in. Try those, I think you'll be happy!
Old Dec 18, 2001 | 07:53 AM
speedymon's Avatar
Default Re: Headgasket (WAFFLES)
YOu guys are chauk full of info! I HT!!
will the r piston drop right into a b18c5? what are other alternatives to R pistons?
[Modified by speedymon, 11:54 AM 12/18/2001]
Old Dec 18, 2001 | 08:03 AM
WAFFLES's Avatar
Default Re: Headgasket (speedymon)
the r pistons are already in the c5. he has a gsr, c1. All b series pistons are interchangeable. The next piston to up the compression would be the jdm itr, then the pr3, then p30, then ctr. And of course, the overbore version of each piston will slightly change the compression compared to the non-overbore.
candy eg
Jun 28, 2006 01:38 PM
tegasaurus
Dec 23, 2003 02:54 PM
KRiS1
Aug 27, 2003 12:07 PM
itr1236
Nov 4, 2001 05:17 PM
DelsolVtec18
Sep 27, 2001 03:12 PM
