08-01 accord, how to remove climate control
Old Oct 17, 2004 | 08:40 AM
lakerschamp2000's Avatar
Default 08-01 accord, how to remove climate control
I removed 2 screws on the bottom and tried to pull it out but something stuck on the top. please help.
Old Oct 17, 2004 | 09:06 AM
oei28's Avatar
Default Re: 08-01 accord, how to remove climate control (lakerschamp2000)
you have to remove the clock first, just pull the clock and it should come out.
Old Oct 17, 2004 | 09:57 AM
cd555's Avatar
Default Re: 08-01 accord, how to remove climate control (oei28)
I believe there is a screw behind the clock too.
Old Oct 17, 2004 | 10:18 AM
thanks for information guys, but how do you remove the clock?
Old Oct 17, 2004 | 10:25 AM
Legendaryyaj's Avatar
Put a flat head under it and pry it out.
Old Oct 17, 2004 | 05:32 PM
Default Re: 08-01 accord, how to remove climate control (Legendaryyaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj &raquo;</TD></TR><TR><TD CLASS="quote">Put a flat head under it and pry it out. </TD></TR></TABLE>
tried that but did not help. look like the clock is built in with the climate control
Old Oct 17, 2004 | 05:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakerschamp2000 &raquo;</TD></TR><TR><TD CLASS="quote">
tried that but did not help. look like the clock is built in with the climate control</TD></TR></TABLE>
You arent trying hard enough. I have dealt with both the auto and manual climate control. Just slide it under the clock and press down, the clock should pop right out.
Old Oct 17, 2004 | 05:58 PM
You arent trying hard enough. I have dealt with both the auto and manual climate control. Just slide it under the clock and press down, the clock should pop right out.</TD></TR></TABLE>
please note that mine is 99 model
Old Oct 18, 2004 | 01:20 AM
Entaka's Avatar
I have a 99 accord and the clock just pulls right out. What I did is aimed the A/c vents down so I could get to the clock. It does look like its built in, but if you look closely theres a small lip. I used my hands to pull it out, a screw driver works too. I just yanked that **** out. I was affraid I was going to hurt it but all was well. Had to replace my bulb, thus the reason I took it out. Theres a site that can help you take it apart. They sell LED's and stuff for light conversions. It used to be called 99accord.com but now its http://www.ledautomotive.com/ So yeah...go there...it will help you out with removing some of the stuff and it has nice pics too. Let me know if I can help with anything else because I have taken apart my WHOLE dash in my 99 sedan. More specificly, heres the page you will need:
http://www.ledautomotive.com/H...l.asp
Old Oct 18, 2004 | 05:50 AM
Turbowa's Avatar
Default Re: 08-01 accord, how to remove climate control (Entaka)
You may also want to try and push the clock out from the back side if you can get your hand back there. Thats how I had to get mine out the first time. After that it came out pretty easy.
Old May 9, 2005 | 08:39 AM
mingbling96's Avatar
Default Re: 08-01 accord, how to remove climate control (Turbowa)
sorry. to bring this up from the dead.. but how do you remove the vents.. without damaging it. It feels like if i pull it out, it'll crack and I'll have to buy a new vent. I'm just interested in replacing the climate control. Anybody have n e tips. I already have the clock off and the screw behind the bolt.
Old May 9, 2005 | 10:38 AM
philadd's Avatar
Default Re: 08-01 accord, how to remove climate control (mingbling96)
There's 3 screws holding the whole thing on... The one behind the clock, and 2 at the very bottom. Remove the screws, then just pry out the whole piece... the climate control will come off with it.
Old May 9, 2005 | 11:28 AM
notoriousB's Avatar
Default Re: 08-01 accord, how to remove climate control (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">There's 3 screws holding the whole thing on... The one behind the clock, and 2 at the very bottom. Remove the screws, then just pry out the whole piece... the climate control will come off with it.</TD></TR></TABLE>
exactly.
/thread
OT: I want an 08 accord!!
Old May 9, 2005 | 02:10 PM
when you say pry.. when i pry, it feels like i'm going to crack something. So you guys say to just keep prying till it pops off?
Old May 9, 2005 | 05:09 PM
notoriousB's Avatar
pry the clock out from the bottom. DON'T PRY THE VENTS. the clock will pop out and there is a screw behind it. the whole bezel will come off easy once the screws are out.
Old May 9, 2005 | 08:10 PM
Default Re: 08-01 accord, how to remove climate control (notoriousB)
i took the clock out and took the screw from behind the clock and the two screws on the bottom. It is not coming out easily.. it feels like if i force it anymore, something will crack.
Old May 9, 2005 | 09:25 PM
MichaelQ's Avatar
Just a little force all the way around, don't apply all the force to one spot.
Old May 9, 2005 | 09:26 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">i took the clock out and took the screw from behind the clock and the two screws on the bottom. It is not coming out easily.. it feels like if i force it anymore, something will crack. </TD></TR></TABLE>
after you take out the three screws, there's six clip that you need to pull out, just apply enough force to take apart
TEAM EoR
Apr 12, 2008 11:26 AM
hondacuraman
Jun 11, 2006 05:49 PM
NVturbo
Jan 1, 2004 05:27 AM
Mr Boston
20
Oct 9, 2003 05:33 PM
PSU
10
Jul 22, 2003 04:07 PM
