CLIMATE control LIGHTS
O.G. triple O.G.
I know this subject has probably been discussed before but I was wondering.... how the hell do you remove and replace the climate control bulbs on a EG6 Civic?Mine are burned out on the right side of the panel. Any help would be appreciated.
Remove you radio, then look up in htere (it's a tight fit). There is a small screw about in the middle, the head is facing the front of the car (making it even more annoying) unscrew that one, then using a couple very small flatheads, or putty knives ( I use a feeler gauge) slide they flatheads on top about 1.5" from either side and release the two clips, then just gently pry the face off.
EDIT: don't forget to pop the slider ***** off first
Global Moderator
Re: (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">Remove you radio, then look up in htere (it's a tight fit). There is a small screw about in the middle, the head is facing the front of the car (making it even more annoying) unscrew that one, then using a couple very small flatheads, or putty knives ( I use a feeler gauge) slide they flatheads on top about 1.5" from either side and release the two clips, then just gently pry the face off.
EDIT: don't forget to pop the slider ***** off first </TD></TR></TABLE>
Well said.
Well said.
O.G. triple O.G.
Re: (92b16vx)
Thanks for the advice ...... will replace next week when off work!!!!
crazy_ls_90
09-14-2008 10:30 PM
lakerschamp2000
05-09-2005 09:26 PM
