Torquing AEBS Head Studs
right now, I'm installing the head studs.
What i did was I dipped them in non-detergent oil and hand tightened them down into the block, once hand tightened, I used an allan key to tighten it a bit more.
but the thing i want to know is that once i've tightened them down with the allan key, do i use a torque wrench to torque them down?
what i normally do is tighten it down with the allan key til it wont go down anymore...i then back out 2 turns...put the head on and toqure in sequence. with lube, i was recomended 75lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorCalAllMtr408 »</TD></TR><TR><TD CLASS="quote">you pre torque the studs to 10 ft lbs. and two step torque sequence 35 ft lbs and 70 ft lbs for the final torque down...</TD></TR></TABLE>
word.
it comes with a sheet of paper for what you should do. and im 99% sure that is what you are supposed to do
word.
BrightRedOne
Oct 24, 2004 09:45 AM
