Broken axle issues
Old Oct 16, 2004 | 06:29 AM
crxgsr91's Avatar
Default Broken axle issues
I just broke an axle yesterday with a lousy 150whp. I was wondering if anybody has had a similar problem. Maby they are the wrong axles here are the part numbers from O'reilly's right axle 60-4121 left axle 60-4063
Old Oct 16, 2004 | 07:10 AM
90 Si Hatch's Avatar
Default Re: Broken axle issues (crxgsr91)
all i can say is buy a higher HP axel or something
Old Oct 22, 2004 | 09:17 AM
HighVelocity's Avatar
You mite not really need high hp axles the axles in your car mite have been old and beating up with a 150whp you just need to swap the bad one and get another one. My friend has a 650 hp turbo lsvtec and he uses stock axles. If it becomes an issue again and again then you should look into some high hp axles or even an issue with your tranny.
Old Oct 22, 2004 | 09:55 AM
jlicrx's Avatar
in checking O'reilly's part numbers, the 60-4063 is the right side axle for 90-93 Integra - the left side axle for 90-93 Integra is 60-4062 - the 60-4121, which you have, is the left side axle for a 94 Integra
Old Oct 22, 2004 | 11:02 AM
Malgerus's Avatar
Default Re: Broken axle issues (White90SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White90SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">all i can say is buy a higher HP axel or something</TD></TR></TABLE>
I wouldn't.
Would you rather break an axle, or a differential?
Old Oct 22, 2004 | 11:28 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Broken axle issues (Mr. S)
What kind of tranny fluid are you running? I broke 3 axles in my J1 trans with a Y1 lsd differential. Until I finally figured out my lsd was eating my alxes. I swapped in a clutch type lsd from one of my buddies trannies he had laying around. I finally figured out that I need to run a lsd additive.
How long have you been having axle problems? Is this the first time you ever had problems. I'm only making 150whp too so that is probably not the problem.
Old Oct 22, 2004 | 02:47 PM
crxgsr91's Avatar
Default Re: Broken axle issues (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">in checking O'reilly's part numbers, the 60-4063 is the right side axle for 90-93 Integra - the left side axle for 90-93 Integra is 60-4062 - the 60-4121, which you have, is the left side axle for a 94 Integra</TD></TR></TABLE>
You are correct the 4121 was completely different the correct left axle part number is 60-4034
Old Oct 22, 2004 | 02:51 PM
crxgsr91's Avatar
Default Re: Broken axle issues (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">What kind of tranny fluid are you running? I broke 3 axles in my J1 trans with a Y1 lsd differential. Until I finally figured out my lsd was eating my alxes. I swapped in a clutch type lsd from one of my buddies trannies he had laying around. I finally figured out that I need to run a lsd additive. .</TD></TR></TABLE>
I use the GM synchro mesh with the additive I read on this board it is great.
.</TD></TR></TABLE>
This is the first axle I have broke. I plan on rebuilding the engine early next year for much higher power and if I am breaking axles with 150whp I would hate to see what they do at 250-300whp.
nonvteclude
Aug 7, 2006 08:45 PM
powerofdreams8
Jun 13, 2006 07:30 AM
flatblack-h22
Mar 7, 2006 11:57 AM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
NikoZai
Jul 28, 2002 09:21 PM
