who has Rotora big brake and 7x16 - which offset
Old Oct 16, 2004 | 06:23 AM
- Sim -'s Avatar
Default who has Rotora big brake and 7x16 - which offset
i have that problem now. i got a set of jdm 16 inch wheels in 7 x 16 offset 50.
and i also have the rotora big brake and it wont fit that way. so which offset to take with spacers?
offset 30? 35? 40 ?
i want to get a low brake clearance as possible. about 5 mm ....
thanks for your help guys
Old Oct 16, 2004 | 01:04 PM
- Sim -'s Avatar
Default Re: who has Rotora big brake and 7x16 - which offset (- Sim -)
nobody an info?
omg
there was one guy who had rotora brake on a py itr. and spoon wheels. he had pics in the forum when he was on dyno who was it?
Old Oct 17, 2004 | 02:18 AM
- Sim -'s Avatar
this car here belongs to who?
rotora big brake and spoon wheels. thinking offset 35 but dunno exact....
Old Oct 17, 2004 | 03:53 AM
RagingAngel's Avatar
From what I understand the Spoon 16X7 wheel only comes in a +42mm offset.
From what I recall on Saga's car, they will clear with no spacers but this is on a Spoon caliper....
I assume you need to run at least a 10mm to clear Rotora brakes.
Old Oct 17, 2004 | 07:05 AM
- Sim -'s Avatar
Default Re: who has Rotora big brake and 7x16 - which offset (RagingAngel)
this is a rotora caliper.
same as mine.
there is rotora printed on and its dark blue like rotora hasm not light blue like spoon uses.
then another:
on spoon website there are 2 wheels:
offset 45
offset 35
and nothin +42
where did you get your infos from? hit that guy with a hammer @ his head :-)
Old Oct 17, 2004 | 08:39 AM
JDM Factor's Avatar
You can try hub-centric wheel spacers.. How close is it?
Old Oct 17, 2004 | 09:56 AM
- Sim -'s Avatar
Default Re: (JDM Factor)
hmm i want to do that.
but i have to know which offset i have to come to with the spacers.
thinking that offset + 35 will fit.
but if + 38 or + 40 will also fit i would like to get this offset.
as much offset as possible i want.
so i need info from the guy that owns this py itr on the pics. he has rotora big brake and 7 x 16 rims....
Old Oct 17, 2004 | 12:26 PM
Padawan's Avatar
Darth ModerVader
Default Re: (- Sim -)
Keep in mind that just because one wheel clears a certain brake setup with a certain offset (e.g., the SW388's in the photo) doesn't necessarily mean that a different wheel with the same offset will clear the same brakes. If I recall correctly, the stock JDM ITR wheels don't offer a tremendous amount of clearance for brakes in the first place.
Old Oct 17, 2004 | 12:43 PM
stumpyf4's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Keep in mind that just because one wheel clears a certain brake setup with a certain offset (e.g., the SW388's in the photo) doesn't necessarily mean that a different wheel with the same offset will clear the same brakes. If I recall correctly, the stock JDM ITR wheels don't offer a tremendous amount of clearance for brakes in the first place. </TD></TR></TABLE>
^^ I agree.
Here's a hint to find what you need:
1) Hit up your local hardware store and buy a bunch of M12 washers.
2) Start stacking washers on the wheels studs and try fitting your wheels.
3) Once you find the appropiate number of washers so your wheel clears, measure the stack height of the washers and match up to the next thickest size of wheel spacer available.
4) Order the wheel spacer and be done with it.
Old Oct 18, 2004 | 03:23 AM
- Sim -'s Avatar
Default Re: (stumpyf4)
hey mans
3 stupid heads
1 idea.
did it that way. need 11 mm
ordered 15 mm. so it shall fit nice.
but i ll get 15 for every wheel also rear. if not i ll look crappy. if front is 30 mm wider than rear arch....
Old Oct 18, 2004 | 03:52 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by - Sim - &raquo;</TD></TR><TR><TD CLASS="quote">hey mans
3 stupid heads
1 idea.</TD></TR></TABLE>
I sincerely hope you aren't grouping me in the first category. Looking back, there wasn't a single "stupid" reply in this thread. Perhaps (hopefully) I'm just misinterpreting this last post...
Modified by Padawan at 8:14 AM 10/18/2004
Old Oct 22, 2004 | 11:19 PM
- Sim -'s Avatar
no no
this is something we say in germany.
it dont really say that you re stupid or so.....
just a kind of sentence you say without so so
papa5murf
Honda S2000
104
Oct 4, 2015 09:09 AM
tomman2001
Oct 31, 2007 07:58 PM
AJ PwR
Honda Fit
26
May 13, 2006 01:37 PM
1337 Si
Mar 27, 2004 11:55 AM
Napolean Solo
Sep 29, 2002 11:31 AM
