BAD NIGHT FOR ME.... blew a rad hose... n im wondering??????
here's wat happen.... i was drivin n drivin breakin in my new motor. n in 4th gear goin 50 on highway the radiator hose busted/came off the back.. next thing i know i see nothin but smoke.... i roll out the next near exit n pop my hood n look....everything seems ok but here's my questions..??
i rolled about a block or two off the highway.. will there be any damage to my motor???
after i got it home i put the hose back on n fill it back up with antifrezz started n it seems ok.... but when i rev it water or antifreez was comin out the exhaust..
how can i check if i blew my head gasket????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman »</TD></TR><TR><TD CLASS="quote">id say you blew your head gasket. which is it coming out of the exhaust water or coolant?</TD></TR></TABLE>
im not sure... it smells lik coolant but once it come out is black water n feels lik water.... but the smell can cuz by the spill on dp/cat... any other way i can check?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaxx4k »</TD></TR><TR><TD CLASS="quote"> how can i check if i blew my head gasket???? </TD></TR></TABLE>
Compresion, Leakdown, and that RAD press test thingy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart »</TD></TR><TR><TD CLASS="quote">Are you using headstuds? </TD></TR></TABLE>
I doubt his head lifted
yes im usin headstud, motor is fully build. when i put the hose back n fill it up i dont see any bubbles....
well after doin sum homework now everythign seems fine... my shop said check my oil n see if it looks miky or is solid oil look... n it looks solid no milky so now i just change the hose n clamps to belt clamps n it starts n run fine...
DUKE LADUKE
Jun 21, 2010 05:33 PM
