losing coolant
Old Jul 18, 2006 | 10:09 PM
Cyber ITR's Avatar
Default losing coolant
heya guys, i have recently notice that the water/coolant level on my resevoir keeps getting low
im not sure if its my headgasket or what, but headgasket is just recently changed like 1200mile ago
if its leaking, where does coolant normally leaks on hondas ???
and the clamps that holding the radiator hose are still factory, im not sure if its normal or not, but i am able to press and move the clamps along the hose
im really confused and pissed off
any help would be greatly appreciated ...
Old Jul 18, 2006 | 10:13 PM
dunkd's Avatar
leaks into the combustion chamber and exits out the exhaust.
Old Jul 18, 2006 | 10:23 PM
Cyber ITR's Avatar
Default Re: (dunkd)
so ur saying that my headgasket is toasted again ???
Old Jul 18, 2006 | 10:28 PM
ImportMotorSpec's Avatar
Default Re: (Cyber ITR)
My guess is head gasket if you havn't seen a leak.
Take it to a shop and they will most likely have a hydro-carbon tester. It takes and sucks air out of the top of the radiator through a "special" liquid and it turns a color if it senses a trace of hydro-carbon.
It is always cool when i get to use it. Customers are always like how do i know that it works. So, i blow at the inlet and the blue liquid turns yellow. Even the "exhaust" from your body will trip fluid.
Old Jul 18, 2006 | 10:31 PM
jononioo's Avatar
Default Re: (ImportMotorSpec)
my radiator busted today and i overheated. You could try checking for any pin sized holes in your radiator or drops of water under your car. If you don't see any my guess would be head gasket.
Old Jul 18, 2006 | 10:41 PM
Cyber ITR's Avatar
Default Re: (jononioo)
uhmm im pretty sure my car does not smoke at all when it fully warm up
at the moment its kinda hard to tell whether the smoke that coming out of the muffler is coolant or just normal steam , is there a way to identify it ?
Old Jul 18, 2006 | 10:42 PM
dunkd's Avatar
leakdown test.
Old Jul 18, 2006 | 10:44 PM
Cyber ITR's Avatar
Default Re: (dunkd)
will compression test tells if i have a blown headgasket ?
Old Jul 18, 2006 | 11:59 PM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyber ITR &raquo;</TD></TR><TR><TD CLASS="quote">will compression test tells if i have a blown headgasket ?</TD></TR></TABLE>
in most case no
Old Jul 19, 2006 | 01:50 AM
Cyber ITR's Avatar
Default Re: (komat)
ok if you guys could answer my last question
for those who thinks my headgasket is toasted again after only 1200miles been changed, say if i starts the engine, the smoke that comes out of the tail pipe should have that sweet-burning-coolant smell, am i right ?
Old Jul 19, 2006 | 09:58 PM
Cyber ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyber ITR &raquo;</TD></TR><TR><TD CLASS="quote">ok if you guys could answer my last question
for those who thinks my headgasket is toasted again after only 1200miles been changed, say if i starts the engine, the smoke that comes out of the tail pipe should have that sweet-burning-coolant smell, am i right ?</TD></TR></TABLE>
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
SeanK325
Jun 22, 2010 02:52 PM
DUKE LADUKE
Jun 21, 2010 05:33 PM
giantdny
Nov 6, 2006 07:13 AM
DC2point0
15
Mar 22, 2006 12:05 AM
