car is bogging in upper rpms...why?
Old Oct 13, 2004 | 07:13 PM
hondaeg8's Avatar
Default car is bogging in upper rpms...why?
once my car hits vtec, it bogs out and doesn't seem to want to move. it hesitates right after vtec hits.
motor is a jdm gsr motor
dc sports header
skunk2 IM
cai
msd ignition kit
i had a b&m fpr on with the fuel pressure set at 40 psi. i also had a walbro 255lph fuel pump in because of the zex kit that have that i never use .
i took the fuel pump and the b&m fpr off and put the stock ones back on so far. i have also changed my spark plugs.
i haven't driven the car yet because its been raining. anything else i should look at that might be making my car do this?
Old Oct 13, 2004 | 07:14 PM
dantastic's Avatar
fuel pressure sounds kind of low... it should be 46-48 psi with the vaccum hose off and pinched
Old Oct 13, 2004 | 07:19 PM
hondaeg8's Avatar
Default Re: (dantastic)
i thought fuel pressure was from 39-43 psi at idle.
my friend has an itr swap and his fuel pressure is at 42psi and he has no problems.
Old Oct 13, 2004 | 07:21 PM
hondaeg8's Avatar
Default Re: (hondaeg8)
also...my ecu is a kenji chipped p28
with my stock fuel pump and stock fpr on, the fuel pressure at idle is 39-40psi.
i have the fuel pressure guage on the fuel filter.
Vtec-Mike
Jan 7, 2006 10:02 AM
Boognish
Jul 24, 2005 08:16 PM
gsrvtechatch93
Mar 12, 2004 04:33 AM
BoostedD15B7
Jan 15, 2004 01:28 PM
IVANITR
May 6, 2002 07:16 PM
