I NEED to know where the hoses on the back of this block (B18C) goes...
Old Oct 13, 2004 | 01:04 PM
TheSwift1's Avatar
Default I NEED to know where the hoses on the back of this block (B18C) goes...
I need a favor:
I have a Helms manual for my B16A, but since I'm swapping in a GS-R bottom end, I need to be exactly sure of where all the hosing on the back of the block goes...
I'm also running a JRSC, so those of you familar with a GS-R and/or JRSC, I could use your imput also (you'll also notice I had to change the angle of the oil cooler per JRSC) ...
or, if you could scan the page of the Helms that shows the hoses to the back of the block, that would help a lot!
thanx guys..
[img][/img]
Modified by TheSwift1 at 10:19 PM 10/13/2004
Old Oct 13, 2004 | 01:31 PM
mchuang's Avatar
i think the 2 on left are for an oil cooler to let coolant flow thru it
Old Oct 13, 2004 | 01:41 PM
donkiman's Avatar
Default Re: I NEED to know where the hoses on the back of this block (B18C) goes... (TheSwift1)
i had similar problems when i swapped in my b18c1. I asked the same question in the tech forum/ hybrid/ civic/ integra forums. ask in all those and you will find alot of helpful answers.
Old Oct 13, 2004 | 02:11 PM
BoostedEG6's Avatar
the one on the black metal hose is the return coming from the heater core.. if you arnt running a heater then you can plug that one.
the bottom left is coming from the oil cooler but I cant remeber where it goes.
Old Oct 13, 2004 | 02:13 PM
ATS*24K's Avatar
Miracle Whips
Default Re: I NEED to know where the hoses on the back of this block (donkiman)
You coneect the two lower fittings together as they are for the oil cooler..the upper left fitting on the water pipe goes to the heater core drivier side fitting
Old Oct 13, 2004 | 04:17 PM
hypa's Avatar
Default Re: I NEED to know where the hoses on the back of this block (ep3hatch)
b16 and b18c blocks have different routings. I found that out the hard way, but it's not a hard fix.
With that said, you're going to end up with an extra hose. What you need to do is *ensure* you have determined what direction the flow goes, and "T" the extra line into an existing one. The hardest part is figuring out which hoses flow where, and getting the "T" in there.
I wish I was there to actually point out what to do, but I'm like 2000miles away from you.
Old Oct 13, 2004 | 04:52 PM
TheSwift1's Avatar
Default Re: I NEED to know where the hoses on the back of this block (hypa)
Old Oct 13, 2004 | 05:26 PM
Turbo-Honda's Avatar
Maybe this might help you out....
Old Oct 13, 2004 | 06:54 PM
kobi2002's Avatar
on the top your also going to have to bend it down a bit because the supercharger will hit it. i went through the same thing when i had mine in and the lower one goes to the one to the right. When you bend that pipe on the top be careful cause even though its metal it can tear. And you don't end up with an extra hose cause the only change you did was move the oil cooler. All your doing is making the hoses longer to make up for thee change of that position.
Old Oct 14, 2004 | 06:05 PM
TheSwift1's Avatar
Default Re: I NEED to know where the hoses on the back of this block (kobi2002)
thanx for all the responses guys!! i'll look into all the input and see what I can find tonight...
Old Oct 17, 2004 | 01:43 PM
hypa's Avatar
I just remembered that when I did the swap, I used the t-stat housing from the b16, thus having one less output. That saved me from T-ing off the final line.
00Red_SiR
Apr 1, 2007 08:40 AM
jbs
Jul 1, 2006 06:48 PM
EG6Krew
Aug 15, 2005 11:02 PM
nomotor
Jun 9, 2004 01:20 AM
92TEGsrSC
Jul 5, 2003 10:13 PM
