camber question
Old Dec 16, 2001 | 05:17 PM
redteg1's Avatar
Default camber question
would a 1.5in drop from prokit springs on a 95gsr (stock shocks) have any negative camber effects?
Old Dec 16, 2001 | 10:38 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: camber question (redteg1)
Not if you get a good alignment.
Old Dec 17, 2001 | 01:32 AM
gsrvx's Avatar
New User
Default Re: camber question (Mista Bone)
1.5 inch drop shouldn't affect the camber too much. But yea, as MistaBone said...get an alignment...as ur toe will be affected. That can kill ur tires too.
-Rod
Old Dec 17, 2001 | 06:31 AM
keithv's Avatar
Default Re: camber question (RK)
I put the Eibach Pro-kit (rated at 1.3" drop F/R) and I did need an alignment after the install.
I would recommend to always get an alignment after installing any kind of lowering springs...
Old Dec 17, 2001 | 10:22 AM
gsrvx's Avatar
New User
Default Re: camber question (breaka_1_9)
Anytime you perform a suspension modification...get an alignment done.
Old Dec 17, 2001 | 02:28 PM
976's Avatar
976
New User
Problem with lowering a car is that sometimes when your wheels/tires don't have a good offset, you lose performance. For instance, if your camber is a couple degrees off, it will angle your wheels outward - causing less traction, less performance. Plus as everyone else said, you will go though tires faster. Rotate often, get alignment...
Old Dec 17, 2001 | 10:58 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: camber question (B21A)
offset DOES NOT effect alignment.
Old Dec 21, 2001 | 01:37 PM
Flamenco-T's Avatar
will I need a special alignment for just a pro-kit on a teg ?
I mean do I need to go to a special lowered car alignment ? they want like 100 at least to do alignment, as opposed to 60 bucks on goodyear...
stan
Old Dec 21, 2001 | 03:06 PM
rioninja's Avatar
Just something to remember, you should drive the car for at least a week before getting the alignment done. This will give everything a chance to settle, such as the springs into the pillowmounts. no sense getting it done twice.
Old Dec 21, 2001 | 03:14 PM
3.3.3's Avatar
Default Re: camber question (RioNinja)
i used to have eibach sportlines on my old dely and the drop was 1.5 the rear camber was perfect, front had a few degrees of negative camber. it never affected my tire wear or steering at all.
no alignment either.
93accordf22a
Jan 20, 2009 08:26 AM
Jesterian
Sep 28, 2006 08:05 PM
JMD
Jul 16, 2003 05:56 PM
IgniteTeg
Apr 17, 2002 07:53 PM
kikkoboyie
Sep 17, 2001 04:26 AM
