Ahh rear swaybar madness!!!!
Old Oct 13, 2004 | 09:20 AM
turbotime's Avatar
Default Ahh rear swaybar madness!!!!
I just got the ST front and rear swaybar kit for my 93 coupe. Do I need some type of special bracket to install a rear sway bar on my 93 ex coupe? I already have rear lca's with mounting points, do i need any other type of brackets, other then the little U clamp thing included in my kit?
Thanks!
Old Oct 13, 2004 | 09:23 AM
Luserkid's Avatar
Default Re: Ahh rear swaybar madness!!!! (turbotime)
I think the U clamps and the mounting points is all that holds it up. Dont quote me on that because i dont have sway bars.
Old Oct 13, 2004 | 12:22 PM
turbotime's Avatar
Yeah but there are no exisitng holes in the rear subframe that line up with the bracket.... Dont I need an integra bracket or something?
Old Oct 13, 2004 | 01:31 PM
RareSI's Avatar
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but there are no exisitng holes in the rear subframe that line up with the bracket.... Dont I need an integra bracket or something?</TD></TR></TABLE>
Yes, I believe that to be true, as the rear suspensions are similar on the 5G Civics compared to the 3G Integras.
Old Oct 13, 2004 | 01:32 PM
D21X's Avatar
Default Re: (RareSI)
i thought u had to redrill a hole in the subframe to mount the sway bar D-link on to the subframe?
Old Oct 13, 2004 | 01:33 PM
slammed_93_hatch's Avatar
Default Re: (D21X)
all 1992-2000 civic have the holes there, most of the time there just covered in ****.
Old Oct 13, 2004 | 01:38 PM
Milano_EH3's Avatar
Default Re: (slammed_93_hatch)
What slammed_93_hatch said. I have ST bars on my '94 hatch. These pictures may help you reference.
Old Oct 13, 2004 | 01:51 PM
turbotime's Avatar
Default Re: (Milano_EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano_EH3 &raquo;</TD></TR><TR><TD CLASS="quote">What slammed_93_hatch said. I have ST bars on my '94 hatch. These pictures may help you reference.
First off thanks alot! Nothing beats getting advice from someone who has the same kit, BTW how do you like it?
Anyway in this pic ^ is there a washer or something between the d brace and the subframe on the bottom hole? I have those two holes but it seems like they arent on the same planar surface (lower hole is recessed)?
Old Oct 13, 2004 | 01:57 PM
.nate's Avatar
Looks like he has the 5lug conversion...
Old Oct 13, 2004 | 02:03 PM
Milano_EH3's Avatar
I believe there is a washer...in fact I think you can see it in the photo. To be quite honest, I can't remember...because I installed this kit about 3 years ago. Many dead brain cells between then and now...but I guess I could run out and look under my car ro double check.
I like the kit...you will def notice a difference. And the front bar is def beefier that the stock bar. Some people have reported those rear brackets ripping out of the holes. But I can't imagine how they would have managed that aside from taking it off-road. I have had 0 problems. Well, I take that back...there was a bit of a clearance issue with my exhaust hitting the rear bar. But that problem seemed to clear itself after I lowered the car.
Old Oct 13, 2004 | 02:04 PM
Milano_EH3's Avatar
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">Looks like he has the 5lug conversion...</TD></TR></TABLE>
Nope...just ITR control arms. I needed them for my Tanabe coil-overs.
Old Oct 13, 2004 | 02:29 PM
turbotime's Avatar
cool, thanks. Yeah ive heard about subframe damage with swaybars before. As far as I know its only improper use/installation that cause damage
Thanks again
Old Oct 13, 2004 | 02:50 PM
undertheradar's Avatar
heres a how-to for that bar (rear at least)
http://home.mpinet.net/~t-hero/STbar.htm
Old Oct 13, 2004 | 03:20 PM
turbotime's Avatar
****! even better
Old Oct 13, 2004 | 03:57 PM
POE's Avatar
POE
thinks for all the good info guys, im puttin mine on this weekend, and thanks for the link go honda-tech!
Old Oct 19, 2004 | 07:26 AM
JUN1OR's Avatar
Default Re: (Vtecin94dx)
I have a how-to on this rear bar if you're interested... Ton's of pictures...
https://honda-tech.com/zerothread?id=988298
-Junior-
super jdm yo
Jun 2, 2009 05:31 PM
p-p-porkchop
Jul 7, 2006 11:08 AM
RAK
Sep 24, 2005 07:34 PM
GS8HFL21
Feb 2, 2005 12:42 PM
