2" diameter downpipe too small?
Old Oct 13, 2004 | 09:16 AM
AzntaggeR's Avatar
TSPeed Factory
Default 2" diameter downpipe too small?
i ordered a SSA t3 manifold off ebay and the downpipe that comes with it is only 2" in diamater. the setup i plan on running this is downpipe to is a 2.5" test pipe to 2.5" greddy mandrel bent exhaust if that helps any. my question is, do you guys thing the 2" downpipe is too small? or would this work fine.
Old Oct 13, 2004 | 09:40 AM
fjt's Avatar
fjt
Default Re: 2" diameter downpipe too small? (AzntaggeR)
too small, it will affect spooling time and you will have a bottleneck on your sistem with that small DP..anyways it is better to custom Fab your own Downpipe..It never bolts 100% right when you buy it like that..Specially SSA je je je...
Old Oct 13, 2004 | 09:46 AM
Finest's Avatar
Is that 2" I.D.? Or O.D.? If that's a total 2" O.D., then damn that's a small *** downpipe! I think my wastegate dump is 2" O.D.! LOL!
Old Oct 13, 2004 | 09:47 AM
djwest24's Avatar
Default Re: 2" diameter downpipe too small? (Finest)
yea...maybe it's a little too small!
Old Oct 13, 2004 | 09:48 AM
dunkd's Avatar
poop
Old Oct 13, 2004 | 10:52 AM
RyanEJ8's Avatar
Get rid of that that pea shootin downpipe!
Old Oct 13, 2004 | 12:14 PM
CivicGSR225's Avatar
i wouldnt even use that ss autochrome manifold
Old Oct 13, 2004 | 12:17 PM
Stewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote"> 2.5" greddy mandrel bent exhaust</TD></TR></TABLE>
When did greddy start makeing 2.5" exhausts for acura/honda applications? Last that I heard is that all their exhaust will bolt up to the stock cat without modification. That means that they all start off at clost to 2" OD.
Old Oct 13, 2004 | 12:32 PM
b16hybridsol's Avatar
Default Re: 2" diameter downpipe too small? (Stewie)
sell it all, research a little more than try again
Old Oct 13, 2004 | 02:21 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: 2" diameter downpipe too small? (b16hybridsol)
ok cool. i'll just sell it and buy a new one.
Old Oct 13, 2004 | 02:23 PM
AzntaggeR's Avatar
TSPeed Factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stewie &raquo;</TD></TR><TR><TD CLASS="quote">
When did greddy start makeing 2.5" exhausts for acura/honda applications? Last that I heard is that all their exhaust will bolt up to the stock cat without modification. That means that they all start off at clost to 2" OD.</TD></TR></TABLE>
well the diameter is 60 mm, which equals out to about 2.3" i believe.
mamaboy
Welding / Fabrication
11
Aug 4, 2005 09:19 AM
opto_isolator
Jul 31, 2004 10:14 PM
R-1303
May 26, 2003 05:58 PM
AllMotorITR
Aug 27, 2002 06:10 AM
