Im switching from a OBD2 B16A2 To B18b1 !! Questions??
Old Oct 12, 2004 | 08:32 AM
Rocks
Guest
Posts: n/a
Default Im switching from a OBD2 B16A2 To B18b1 !! Questions??
Well im picking up a longblock next week . Just the longblock and axles. What will I need to make this swap work. The long block includes the manifold, the dizzy, the tb too.
Old Oct 12, 2004 | 08:39 AM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
well what exactly are you trying to do, what car and what not?
Old Oct 12, 2004 | 08:41 AM
Rocks
Guest
Posts: n/a
Default Re: Im switching from a OBD2 B16A2 To B18b1 !! Questions?? (Rocks)
Im going to turbocharge my car and want to do b18b instead of b16a2. The setup will be b18b1 + b16 tranny. Im trying to change blocks but I think I might need a wiring harness since im pretty sure that my harness wont fit on the b18b1. Right?
Rocks
Guest
Posts: n/a
BTW the car is a 99 Civic Si
Old Oct 12, 2004 | 01:54 PM
supertran25's Avatar
your going to need a b1 harness. remember your no longer goin to have vtec so it will be a different setup. Also you might want to run a ls tranny for turbo it has longer gear ratios.
Old Oct 12, 2004 | 02:34 PM
dantastic's Avatar
Default Re: Im switching from a OBD2 B16A2 To B18b1 !! Questions?? (supertran25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supertran25 &raquo;</TD></TR><TR><TD CLASS="quote">your going to need a b1 harness. remember your no longer goin to have vtec so it will be a different setup. Also you might want to run a ls tranny for turbo it has longer gear ratios.</TD></TR></TABLE>
WRONG. if you get a obd2 b18b1 ($650 from attarco.com, w/ waranty, but no accessories) everything should plug into your stock harness. if it doesnt, you can replace the sensor/etc with one from your b16. you will have 3 plugs left over: vtec soleniod, vtec oil pressure, and knock sensor
Old Oct 12, 2004 | 04:56 PM
sschouest's Avatar
Are You retarded! Why do you want to loose VTEC. you are going from a SI motor with 160hp to an LS motor with 140hp/non-vtec then you put 3000$ for a turbo and gain 30-40% thats dumb...DO NOT LOOSE VTEC...the only way else to do it is put the LS engine in and add the SI head which will give you VTEC again...then you go back to 160hp...but it is a waste of money and time...
Old Oct 12, 2004 | 05:33 PM
00DC2's Avatar
Default Re: Im switching from a OBD2 B16A2 To B18b1 !! Questions?? (sschouest)
wdup wdup yall..jus joined dis honda tech thang....i agree wid you. dont go nonVTEC. no disrespect or nothin but thats dumb. keep ya VTEC n go turbo...like me. . . .
Old Oct 12, 2004 | 05:37 PM
00DC2's Avatar
Default Re: Im switching from a OBD2 B16A2 To B18b1 !! Questions?? (TuRBo_uP_iN_huRRR)
ey yo how bout last night. this ricer flys by me like he think he gon burn me yo...so i went n floored da throttle n zoomed past that dude. n then we got stopped at the frunt da stop light n when the lite went green..i was gone yo. n i was laughin cus that ricer fly by pissed me off n i ended up burning the guy real bad. then i waited fo him n started crackin up wen he wud right thurr.
Old Oct 12, 2004 | 05:43 PM
freakin_eLRoD's Avatar
are you staying obd2 or going obd1?
Old Oct 12, 2004 | 06:03 PM
GTlvr82's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TuRBo_uP_iN_huRRR &raquo;</TD></TR><TR><TD CLASS="quote">ey yo how bout last night. this ricer flys by me like he think he gon burn me yo...so i went n floored da throttle n zoomed past that dude. n then we got stopped at the frunt da stop light n when the lite went green..i was gone yo. n i was laughin cus that ricer fly by pissed me off n i ended up burning the guy real bad. then i waited fo him n started crackin up wen he wud right thurr.</TD></TR></TABLE>
English ************ do you speak it....and to the guy above me....Semper Fi....Former Marine here....
Old Oct 12, 2004 | 06:13 PM
DOHC_EG6's Avatar
if i were you id stick with v tech it helps a lot. if your want b18b at least put a v tech head on it. i believe you could keep the b16a head. just go ls v it worked for me. i got a b18b block and a type r head.
Old Oct 13, 2004 | 09:23 AM
Rocks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sschouest &raquo;</TD></TR><TR><TD CLASS="quote">Are You retarded! Why do you want to loose VTEC. you are going from a SI motor with 160hp to an LS motor with 140hp/non-vtec then you put 3000$ for a turbo and gain 30-40% thats dumb...DO NOT LOOSE VTEC...the only way else to do it is put the LS engine in and add the SI head which will give you VTEC again...then you go back to 160hp...but it is a waste of money and time...</TD></TR></TABLE>
WTF Dude **** Vtec. Im not doing the swap to loose vtec. im doing it because I want a better engine for forced indunction. Lower Compression a bit easier to tune and 1.8L &gt; 1.6L . WTF 3000K Dollars for a turbo system. I have my mani, wg, bov, piping, fuel lines, and a precision small IC all I need is the turbo dp and a fuel system witch will most likeley be uberdata but Im leaning towards hondata ...maybe. 30-40% 40% of 140 is 56 so it will be 196. No you are wrong sir you are so wrong. It all depends on the PSI you run . For me it will most likeley be 14-15 PSI and push around 300whp and about 260 tq. So shut up dude. Its my engine and my money. If I want to waste it on something you dont like ill do so. And I have a B16a2 that will most likeley be swapped in another car and have fun with that car too.
Old Oct 13, 2004 | 09:48 AM
kine462's Avatar
yeah dude it's his money and vtec has too much hype. ans besides he's going turbo. don't get me wrong I am not knocking vtec, I have it, i love when it kicks in. but why would you need vtec when you could have a cam profile that is almost as aggressive as vtec all the time, coupled with a good spooling turbo, you would wail on n/a civics or integras with vtec. unless your against an nsx. or maybe an s2000 those might wail on civics and integras either way.RWD rocks
Old Oct 13, 2004 | 09:50 AM
mckenzie's Avatar
b16's suck ***
Old Oct 13, 2004 | 09:54 AM
mattssi's Avatar
there sure was a lot of newie e-thug people in this thread? About the b16-ls swap, it will be a nice setup, and like you said, you can put that b16 longblock to better use in maybe a smaller car, or even sell it to help pay the way for a nice fuel management system, or something else turbo oriented... good luck.
Old Oct 13, 2004 | 10:01 AM
Rocks
Guest
Posts: n/a
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">there sure was a lot of newie e-thug people in this thread? About the b16-ls swap, it will be a nice setup, and like you said, you can put that b16 longblock to better use in maybe a smaller car, or even sell it to help pay the way for a nice fuel management system, or something else turbo oriented... good luck. </TD></TR></TABLE>
Honestley dude I want to just take good care of the B16a2 because when Im ready to sell my car It wont lose that much value and just in case my engine ever blows up and need a car real bad I have a backup engine.
Old Oct 13, 2004 | 10:07 AM
ek9800's Avatar
dude you're 14 u dont drive shut up...and if he wants to get rid of vtec let him its his money his car and he does what he wants with it..but youll miss it
Old Oct 13, 2004 | 10:12 AM
Rocks
Guest
Posts: n/a
Default Re: Im switching from a OBD2 B16A2 To B18b1 !! Questions?? (DOHC_EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC_EG6 &raquo;</TD></TR><TR><TD CLASS="quote">if i were you id stick with v tech it helps a lot. if your want b18b at least put a v tech head on it. i believe you could keep the b16a head. just go ls v it worked for me. i got a b18b block and a type r head.</TD></TR></TABLE>
VTEC not V-Tech thats I think is a phone maker company. Dorks
Old Oct 13, 2004 | 11:01 AM
senpai's Avatar
god damn, most of these fools have no idea what they're talking about ... I feel ashamed
Old Oct 13, 2004 | 11:07 AM
JDM EJ1 95's Avatar
yep .. DATS HONDA TECHHHH Y0! MAD TYTE VTECHKX MAN!
civicSiR1.6
Nov 11, 2011 11:16 PM
Bmans96civic
14
Mar 17, 2009 06:17 AM
esean93
15
Sep 13, 2008 05:36 PM
turbo_d
Apr 1, 2008 07:24 PM
ballerchild
12
Apr 3, 2007 12:41 PM
