What to convert on engine harness?
I'm about to swap in a obd2 b18b in my 98 EK. The thing is, the car had a obd1 b16 in it before. The engine harness is still there and it was just wired for vtec. What I need to know now is what I have to do to the existing harness in order for me to run the b18b.
Re: What to convert on engine harness? (ballerchild)
just reuse the obd1 harness swap out the distributor injectors and engine harness everything should plug right in
Re: What to convert on engine harness? (hybridmath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmath »</TD></TR><TR><TD CLASS="quote">just reuse the obd1 harness swap out the distributor injectors and engine harness everything should plug right in </TD></TR></TABLE>
well the harness is an obd2 engine harness. It was just made to fit all the obd1 plugs. I was wondering what I need to change back to obd2 to work on the LS
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Just reuse all the stuff from your old setup. No need to convert anything over. </TD></TR></TABLE>
the old b16 swap is long gone.. any ideas?
Re: (ballerchild)
Your gonna have to switch over the dist. plug, injector plugs, and alt. plug everything else should be fine! i jus threw my 97 ls in my girls ek 4 door, it prev had an obd1 b16 in it! i used my ls ecu also
Re: (ballerchild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ballerchild »</TD></TR><TR><TD CLASS="quote">the old b16 swap is long gone.. any ideas?</TD></TR></TABLE>
Do you still have your engine harness? Just pick up an engine harness for your car and get a jumper harness. Then you could use everything on the motor.
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Do you still have your engine harness? Just pick up an engine harness for your car and get a jumper harness. Then you could use everything on the motor. </TD></TR></TABLE>
yea, the original engine harness is still attached to the chasis, its wired for vtec and it was converted to run the obd1 motor.
ExtraBlackRex
07-07-2011 03:10 PM
Choy
02-25-2010 03:07 PM
FritzInTN
07-10-2004 09:45 AM
