how much hp will the honda ignition take before it starts to break up?
Old Oct 11, 2004 | 03:56 PM
vaporboy12's Avatar
Default how much hp will the honda ignition take before it starts to break up?
Old Oct 11, 2004 | 03:57 PM
lanojp1's Avatar
Default Re: how much hp will the honda ignition take before it starts to break up? (vaporboy12)
600?
hondas have very good ignition systems...
Old Oct 11, 2004 | 04:18 PM
PrettyLude's Avatar
around 400whp
Old Oct 11, 2004 | 04:20 PM
lanojp1's Avatar
Default Re: (PrettyLude)
i thinks its more than 400, there are pro drag cars with stock ignition systems...
Old Oct 11, 2004 | 04:27 PM
vaporboy12's Avatar
Default Re: (lanojp1)
cause im shotting for 500whp on my new motor in like 2 weeks and i want to know if the stock ignition is up to par
Old Oct 11, 2004 | 04:38 PM
rmcdaniels's Avatar
Default Re: (vaporboy12)
When I got up around 20 lbs of boost it started missing. I tried the MSD cap/CDI/coil combo, which worked if I kept the plugs gapped close, like .020 . Now I have COP, no misses at 20+ PSI with a .040 gap.
Old Oct 11, 2004 | 05:44 PM
*Boostwerks*'s Avatar
Default Re: (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">When I got up around 20 lbs of boost it started missing. I tried the MSD cap/CDI/coil combo, which worked if I kept the plugs gapped close, like .020 . Now I have COP, no misses at 20+ PSI with a .040 gap.</TD></TR></TABLE>
COP?
Old Oct 11, 2004 | 05:46 PM
Bailhatch's Avatar
Default Re: (Bryson)
coil on plug
Boostin Ex's Avatar
COP Coil On PLug ignition system...
Old Oct 11, 2004 | 05:52 PM
Oh yeah. Didn't think of that. haha.
Old Oct 12, 2004 | 02:20 AM
GodFather of Boost's Avatar
I have made 600+ on stock ignition including wires. Plugs gapped at .25
Old Oct 12, 2004 | 04:33 AM
RRL's Avatar
RRL
Default Re: (GodFather of Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GodFather of Boost &raquo;</TD></TR><TR><TD CLASS="quote">I have made 600+ on stock ignition including wires. Plugs gapped at .25</TD></TR></TABLE>
is that .25mm? or .025"?
How do you know if the stock coil is not enough already? do you get detonations? or it just misfires? Thanks!!!
Old Oct 12, 2004 | 06:52 AM
rmcdaniels's Avatar
Default Re: (RRL)
misfires, mine weren't very noticeable, but they showed up on the dyno chart and affected performance
Old Oct 12, 2004 | 07:18 AM
FOrSfEd's Avatar
so all you really notice are misfires? Anything else
Old Oct 12, 2004 | 07:24 AM
rmcdaniels's Avatar
Default Re: (FOrSfEd)
Just misfires, and I didn't even notice them, but they showed up on the dyno. There's some other less quantifiable stuff too, like the possibility of adding more fuel earlier with a stronger spark and a bigger gap, but I'd have to set up a controlled test for that and dyno tuning time ain't cheap.
Old Oct 12, 2004 | 09:51 AM
Default Re: (RRL)
sorry i meant .025 and yes you will start noticing misfires on the dyno graph before you will feel them. That will be the point at which you will actually make power with an aftermarket ignition system.
Old Oct 12, 2004 | 09:59 AM
PrecisionH23a's Avatar
Prelude ignition systems are a bit finickier than the B series. Typically around 330-400 they may start to break up a little bit.
Prelude's also have a lower msbc than the B series do which also does not help.
nowidriveacivic
Engine Management and Tuning
17
Aug 5, 2010 09:29 AM
bobbyeg6
Feb 21, 2010 12:44 PM
dunkd
Aug 9, 2004 05:25 AM
^jefs0ng
Oct 28, 2003 02:53 PM
tegrakid
Jul 23, 2003 11:03 PM
