civic transmission questions
Old Oct 10, 2004 | 11:28 PM
rotaryguy's Avatar
Default civic transmission questions
am i mistaken in assuming that a '98 dx civic will have taller gearing than a '96 ex? if so, if i were to be able to locate a transmission out of a '96 EX, would it be a straight-across swap into a '98 DX?
would this make any sort of difference in the get-up of the '98 civic?
Old Oct 11, 2004 | 05:18 AM
JDMallTHEway's Avatar
Default Re: civic transmission questions (rotaryguy)
I could be wrong, but I think the DX has shorter gears than the EX. but yes, both trannys will swap. the shorter gears will give you better acceleration, but the longer ones will giv e you better mpg and a higher top end.
Old Oct 11, 2004 | 05:31 AM
Deemeetree's Avatar
Electrician
Yes, any time you place a shorter geared transmission into a vehicle, the vehicle WILL be faster in all gears.
Yes, the 1996-2000 Honda Civic EX transmission is the shortest of all the D-Series transmissions. It is a straight plug and play swap.
Old Oct 11, 2004 | 06:07 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotaryguy &raquo;</TD></TR><TR><TD CLASS="quote">am i mistaken in assuming that a '98 dx civic will have taller gearing than a '96 ex?</TD></TR></TABLE>
You are not mistaken. DX transmissions are geared longer than EX transmissions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if so, if i were to be able to locate a transmission out of a '96 EX, would it be a straight-across swap into a '98 DX?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">would this make any sort of difference in the get-up of the '98 civic?</TD></TR></TABLE>
Yes.
Old Oct 11, 2004 | 06:24 AM
shorty0o29's Avatar
Default Re: civic transmission questions (Targa250R)
yeah the dx tranny has longer gears= slower acceleration
and lower rpm's on the highway= better gas mileage
Old Oct 11, 2004 | 06:35 AM
Gesundheit's Avatar
Default Re: civic transmission questions (shorty0o29)
EX tranny+GM Syncromesh+Short throw shifter= 100% increase in the fun factor while driving.
Old Oct 11, 2004 | 06:37 AM
civiccpedx's Avatar
Default Re: civic transmission questions (Crankdriven)
The ex has the shortest gearing that you can get for the d series. And as long as it is 96-00 it should fit right up.
Old Oct 11, 2004 | 06:55 AM
Deemeetree's Avatar
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crankdriven &raquo;</TD></TR><TR><TD CLASS="quote">EX tranny+GM Syncromesh+Short throw shifter= 100% increase in the fun factor while driving.</TD></TR></TABLE>
You forgot Energy Suspension shifter bushings.
Old Oct 11, 2004 | 06:58 AM
Gesundheit's Avatar
Default Re: civic transmission questions (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">
You forgot Energy Suspension shifter bushings. </TD></TR></TABLE>
Ahh yes, those are a good thing as well...
Old Oct 11, 2004 | 09:26 AM
rotaryguy's Avatar
thanks for the replies, fellas. anybody know where i can get a factory-spec clutch on the cheap?
Old Oct 11, 2004 | 09:29 AM
Deemeetree's Avatar
Electrician
http://www.clutchcityonline.com
$101 for an OEM Exedy Replacement with clutch, pressure plate and throwout bearing.
97_ek_coupe
Dec 16, 2013 08:01 AM
ffHeart
Feb 21, 2006 05:08 PM
Hybrid CRX
Mar 25, 2003 08:19 PM
YellowCivic95
Mar 27, 2002 06:45 PM
