civic transmission questions
am i mistaken in assuming that a '98 dx civic will have taller gearing than a '96 ex? if so, if i were to be able to locate a transmission out of a '96 EX, would it be a straight-across swap into a '98 DX?
would this make any sort of difference in the get-up of the '98 civic?
Re: civic transmission questions (rotaryguy)
I could be wrong, but I think the DX has shorter gears than the EX. but yes, both trannys will swap. the shorter gears will give you better acceleration, but the longer ones will giv e you better mpg and a higher top end.
Electrician
Yes, any time you place a shorter geared transmission into a vehicle, the vehicle WILL be faster in all gears.
Yes, the 1996-2000 Honda Civic EX transmission is the shortest of all the D-Series transmissions. It is a straight plug and play swap.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotaryguy »</TD></TR><TR><TD CLASS="quote">am i mistaken in assuming that a '98 dx civic will have taller gearing than a '96 ex?</TD></TR></TABLE>
You are not mistaken. DX transmissions are geared longer than EX transmissions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">if so, if i were to be able to locate a transmission out of a '96 EX, would it be a straight-across swap into a '98 DX?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">would this make any sort of difference in the get-up of the '98 civic?</TD></TR></TABLE>
Yes.
Yes.
Yes.
Electrician
Re: civic transmission questions (Crankdriven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crankdriven »</TD></TR><TR><TD CLASS="quote">EX tranny+GM Syncromesh+Short throw shifter= 100% increase in the fun factor while driving.</TD></TR></TABLE>
You forgot Energy Suspension shifter bushings.
Re: civic transmission questions (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">
You forgot Energy Suspension shifter bushings. </TD></TR></TABLE>
Ahh yes, those are a good thing as well...
Electrician
http://www.clutchcityonline.com
$101 for an OEM Exedy Replacement with clutch, pressure plate and throwout bearing.
97_ek_coupe
12-16-2013 08:01 AM
