9:9:1 comp D and ihi rhb5?
i was wondering if this setup would be ok to run with (y7/y8 minime with 7-9 psi of boost)...i saw another member with a 10:6 compression (d15/y8 head) runnin 9 psi...and seems like he is doing well with his setup...is 9:9:1 to much? or ok?...i plan to use uberdata..have the p28 w/ basemap already...and would i be ok to run on a basemap for now? just tryin to do some stuff while my vitara setup is being built...any suggestions would help...
Screw you guys, I'm... going... home.
As long as you use a good intercooler and well tuned engine management you should be fine. No, I wouldn't boost AT ALL on a base map.
