Front main seal
Anyone know how long it takes and if there is anything special I should look for in doing this? I have the Oil Pump Install Kit so I have all the gaskets (but no oil pan gasket) to remove and install this. From what I have seen you need to remove the whole timing cover and all that.
Just would like to hear from some that have done this already. Thanks
you will need to pick up some sort of maual sucha as a Helms, or at the very leats a Haynes.
it will require a little work, but shouldn't be anything that you couldn't handle granted you are somewhat mechanically inclined.
lucid77
Aug 16, 2013 09:58 AM
diyer
Apr 28, 2004 10:07 AM
