Honda Help Needed With ABS!!!
Old Oct 9, 2004 | 07:40 PM
southpole12's Avatar
Default Honda Help Needed With ABS!!!
Hey I have a 94 ex civic and the abs light is on. Also when I hit the brakes hard the pass side front wheel locks up. Im thinking that its the sensor but im not sure, I would appreciate some feedback. Thanks
Old Oct 10, 2004 | 07:00 AM
Chiovnidca's Avatar
Default Re: Honda Help Needed With ABS!!! (southpole12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by southpole12 &raquo;</TD></TR><TR><TD CLASS="quote">Hey I have a 94 ex civic and the abs light is on. </TD></TR></TABLE>
What trouble code does it have stored?
Old Oct 10, 2004 | 11:29 AM
Default Re: Honda Help Needed With ABS!!! (Chiovnidca)
the engine light is on to but its just reading the o2 sensor code, nothing about abs??? lmk asap. thanks
Old Oct 10, 2004 | 01:29 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by southpole12 &raquo;</TD></TR><TR><TD CLASS="quote">the engine light is on to but its just reading the o2 sensor code, nothing about abs??? lmk asap. thanks</TD></TR></TABLE>
What about ABS codes?
Old Oct 10, 2004 | 05:09 PM
there are no abs codes. just the o2 sensor code 4 slow blinks and 1 fast blink. and than it just does that over and over?? so why would it not read a abs code if the abs light is on, i never thought of that??? thats wierd??? give me some input. thanks alot
Old Oct 13, 2004 | 07:16 AM
somone help me out
Old Oct 13, 2004 | 07:36 AM
Nic's Avatar
Nic
To read abs codes you need a diag computer and special software to read the ABS codes. I would go to a good shop and just pay them to do this. here in VA we charge 65 to read ABS codes.
Old Oct 13, 2004 | 07:55 AM
spoonek9's Avatar
Default Re: (stk crx)
When the ABS light comes the system is disabled. If only one wheel is locking up and you think both should be, I'd pull your wheels off and look at your brake pads and calipers, they should look identical for the most part. While it's jacked up, I would spin your wheels to make sure the spin freely, then hit the brakes and spin them again to see if they still spin freely. If you still can't figure it out, take it to a good shop, at least you tried something though.
Old Oct 13, 2004 | 09:56 AM
Cory man's Avatar
Default Re: (spoonek9)
Older Hondas dont need any scantool equipment to pull ABS codes. These codes are pulled the same way the CEL codes are. Im not sure exactly where the jumper connector is(I think its under the passenger seat) but once it is jumpered the ABS light will blink just like the CEL does. Count your blinks and fix the prob. HTH
tobytigger
Jun 23, 2015 04:31 PM
IntegraLs94Cam
Mar 29, 2005 05:24 PM
Pullig
Jan 18, 2005 08:32 AM
quazar
Jul 14, 2004 01:33 AM
