help help!!!! type r swap no power
Old Oct 9, 2004 | 12:59 PM
3nhanced's Avatar
Default help help!!!! type r swap no power
this is what i got integra gsr shell 95 with an obd1 ..and swaped an type R engine and used the obd2 harness hooked everything up and try to start ...key turns but no power ...? checked the fuses, checked battery...everything good...im thinking it might be a harness problem..? any body have this problem or know what it could be,,???
Old Oct 9, 2004 | 01:05 PM
Jon D's Avatar
Default Re: help help!!!! type r swap no power (3nhanced)
JDM or USDM motor?
Old Oct 9, 2004 | 01:22 PM
uNF$@#!'s Avatar
could be just about anything.
pull out a volt meter and start tracing.
does the starter turn over?
Old Oct 9, 2004 | 02:54 PM
mikestypeRR's Avatar
Default Re: help help!!!! type r swap no power (w@@t w@@t)
maybe cause you stole the motor ... and it dosent like you now.
were did you get this motor from
any R's stolen say within a hundred mile raduis of new mexico... check this guy out.. could be your motor
Old Oct 9, 2004 | 03:43 PM
3nhanced's Avatar
Default Re: help help!!!! type r swap no power (mikestypeRR)
aint stolen man...hahha..budy of mine sold it to me kuz hes doing a rsx type r swap in his type r......and its usdm
Old Oct 9, 2004 | 03:46 PM
Sinbro2's Avatar
we need more info to help you about like stated above. What happens when you turns the key? Does it even crank?
Old Oct 9, 2004 | 03:55 PM
3nhanced's Avatar
Default Re: help help!!!! type r swap no power (Sinbro2)
it doesnt crank..... no juice at all...maybe because its ob2 engine harness to obd1????
Old Oct 9, 2004 | 04:02 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3nhanced &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt crank..... no juice at all...maybe because its ob2 engine harness to obd1????
immobilizer.
Old Oct 9, 2004 | 04:27 PM
Sinbro2's Avatar
try this in the hybrid forum. might get more responses
Old Oct 9, 2004 | 04:55 PM
kchungb17a's Avatar
It would still crank despite an unprogrammed/nonexistant immobilizer. Like the man said, pull out the meter and see where you're loosing the voltage. It might just be a bad connection at the battery.
Old Oct 9, 2004 | 05:11 PM
allmotaR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">
immobilizer.</TD></TR></TABLE>
and might I ask why you'd think that would be the problem?...unless there's some new high tech motor immobilizer, then this isn't the problem. The immobilizer is only in the ecu. Could be a disconnected ground wire.
Old Oct 9, 2004 | 05:26 PM
3nhanced's Avatar
we are running an obd1 computer chipped with type r map....would we still need the mobilizer?
Old Oct 9, 2004 | 05:27 PM
3nhanced's Avatar
Default Re: help help!!!! type r swap no power (twincaman)
checked the ground wire? everything looks fine -=*)
Old Oct 9, 2004 | 06:03 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3nhanced &raquo;</TD></TR><TR><TD CLASS="quote">this is what i got integra gsr shell 95 with an obd1 ..and swaped an type R engine and used the obd2 harness </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3nhanced &raquo;</TD></TR><TR><TD CLASS="quote">we are running an obd1 computer chipped with type r map</TD></TR></TABLE>
You have an OBD1 car and an OBD1 ECU, but an OBD2 harness? Your pinouts are probably wrong somewhere.
Old Oct 9, 2004 | 06:19 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twincaman &raquo;</TD></TR><TR><TD CLASS="quote">
and might I ask why you'd think that would be the problem?...unless there's some new high tech motor immobilizer, then this isn't the problem. The immobilizer is only in the ecu. Could be a disconnected ground wire. </TD></TR></TABLE>
hey fucktard, i didnt read the damn description accurately.
not does it matter anyhow at this point no ones going to be able to help him with such a vague inquiry.
Old Oct 13, 2004 | 01:27 AM
allmotaR's Avatar
i was just sayin..
Old Oct 13, 2004 | 01:48 AM
OCAUTOCARE's Avatar
What ECU are you using?
OCAUTOCARE's Avatar
Default Re: help help!!!! type r swap no power (seantypers)
You might want to try someones JDM ECU to bypass the imobolizer?
Old Oct 13, 2004 | 04:57 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinbro2 &raquo;</TD></TR><TR><TD CLASS="quote">try this in the hybrid forum. </TD></TR></TABLE>
ie. the correct forum.
Old Oct 20, 2004 | 03:49 PM
G-money's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3nhanced &raquo;</TD></TR><TR><TD CLASS="quote">checked the ground wire? everything looks fine -=*)</TD></TR></TABLE>
did you check the ground wire on the thermostat housing? that will cause it not to power up...ecu fuse, bad connection, anything like that
sparkz_kzn
Jan 27, 2007 12:56 PM
3nhanced
Nov 1, 2004 02:46 PM
3nhanced
Oct 9, 2004 01:48 PM
JDMPARTS4U
Mar 20, 2003 12:19 PM
