CTR pistons .25 O/S
CTR pistons .25 O/S
Can someone running these pistons explain the process in order to put these pistons in my B18C. my B18C is stock,
do they make the CTR pistons the same size as the ITR ones ?or do you need to hone out the cylinders ? TIA
Re: CTR pistons .25 O/S (JeffS)
my cylinder walls are brand new . they are in perfect conditions. what size CTR piston would i need to buy for the ITR. thanks again
Re: CTR pistons .25 O/S (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">both</TD></TR></TABLE>
(i.e. they are the same size )
Guest
Posts: n/a
Re: (SPOONfdEK)
this info is very easy to find,what you need to search for is B16b bore, then check B18C bore, and you'll find enough info to answer your question,
just search ctr piston and you come up with a very broad range of topics that wil bring alot to light and make your project alot easier.
SEARCH - not even 2 days ago did this same topic get asked in here. you are new. your question has beeen asked before. your idea isnt original therefore someone else has most likely already asked/answered the info you are searching
https://honda-tech.com/zerothread?id=1026985
Re: CTR pistons .25 O/S (SPOONfdEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONfdEK »</TD></TR><TR><TD CLASS="quote">Can someone running these pistons explain the process in order to put these pistons in my B18C. my B18C is stock,
do they make the CTR pistons the same size as the ITR ones ?or do you need to hone out the cylinders ? TIA </TD></TR></TABLE>
all you need to do is hone the block to install the pistons
Re: CTR pistons .25 O/S (EEK)
thanks EEK and irev210, im not going to get into it with you bluer, it takes you longer to be an ******* than it does to help me out, if you dont want to answer something then just go on your way , but no here you come to be the H-T hero and tell me to search, if i asked its because i dont know, and i dont know what to search for exactly .
Re: (Chiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiller »</TD></TR><TR><TD CLASS="quote">can just put these in but could the car run fine with no tuning?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=717928
That's a lot of compression for no 'fine tuning'.
cthan3o3
08-22-2005 10:54 PM
LSvtechatch97
04-17-2005 12:47 AM
