problem with enjo motor mount
I got the enjo motor mount for my eg for an h series motor. the transmission mount however doesnt fit right. the hole in the mount doesnt line up with the hole on the chasis. is it supposed to be like this? i dont want to drill a hole in anything if i dont have to. i havent been able to get in touch with enjo either. i dont know if they sent me the wrong mount or if its supposed to be like this. any help is appreciated. thanks
you have to cut off the transmission chassis bracket like half way and drill yourself a new hole. While your at it make sure your engine is sitting level so you know exactly how low or high to drill the hole. Yes it is supposed to be that way, i think all the kits are the same way because the tranny is so wide, the chassis bracket gets in the way.
You have to cut it and drill out the smaller hole thats already there, and that's where the mount bolts to. Like here: http://img.photobucket.com/alb...t.jpg
Also like already asked was your car a manual or auto?
it was manual. the instructions that came with the mount get pretty detailed at some points but never say anything about drilling a new hole so i wanted to make sure. thanks for the help
spooncivicsi
Welding / Fabrication
May 6, 2005 06:28 AM
trbob16a
Sep 13, 2002 02:23 PM
