timing
Old Oct 8, 2004 | 06:36 PM
Kirt Porter's Avatar
Default timing
I broke the tensioner boss so I took it to work and tig welded the boss and re tapped the hole. Now I got the belt on and when I line the marks up on the crank pully to the timing cover and the hash marks on th cam gear with the deck of the head. So to set the tension I loosen the tensioner and turn the crank three teeth on the cam pully and tighten the tensioner.So now when I turn the crank over by hand one revolution the marks don't line up so I did it twice three and four revolutions I still cant get the crank pully mark to line up with the timing cover marks. What the hell am I doing wrong
Old Oct 8, 2004 | 09:10 PM
Kendall's Avatar
It's rare that it ever lines up perfectly, in fact in most cases it's usually off by about half a tooth. Make sure that "half a tooth" is advanced, not retarded and you should be good.
Project_CD5
Jul 25, 2007 03:20 AM
Concept Tuning
Jun 29, 2006 06:33 PM
yuckymucky
Mar 23, 2003 10:22 AM
SC94DB8
Aug 23, 2002 04:24 PM
SC94DB8
Aug 23, 2002 09:39 AM
