Major starting problems
Old Oct 7, 2004 | 05:41 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Major starting problems
i have a problem with my starting.
i turn the key to crank and the starter just clicks. i tun the key off and back to crank sevral times each trying to crank but just clicking and after 7 or 8 times the starter cranks fine and starts the engine normaly.
if i hook up my control wire of the starter to the + on the battery with the ignition on, it will start right up.
i repalced the starter today at school (lower bolt was a major pain in the *** ) and buypassed the ignition swich (that's right i hot-wired my own car ) and i still have this problem
Old Oct 7, 2004 | 06:55 PM
89hbcivicguy's Avatar
Default Re: Major starting problems (DieMaster)
replace your + and - wires going to starter it sounds like its not gettin the power it needs....
Old Oct 7, 2004 | 07:07 PM
Mr_CRX's Avatar
bump cause mine does the same thing...
Old Oct 7, 2004 | 08:29 PM
DieMaster's Avatar
Default Re: Major starting problems (89hbcivicguy)
it's still the stock wires
should i replace the wires with some custom ones?
also should i replace the + only or the ground ones too?
Old Oct 7, 2004 | 09:26 PM
Redline130's Avatar
How's the condition of your battery terminals? If their kinda crusty, that could be your problem.
Old Oct 7, 2004 | 09:35 PM
zad5's Avatar
maybe the contacts on the starter. my friend in hawaii called me had the same problem different car ended up changing ht ebaterry and it was all good. pull the battery go to kragen tell them to check it out. and clean the terminal as redline said.
Old Oct 7, 2004 | 09:48 PM
flawlessdjl's Avatar
i had this problem. it was the electric part of my ignition.(the part behind the key) the way i found out(you can use it to check yours) is when you turn the key to the on position, and hear the click, but nothing happens, back off from turning the key all the way,move it a little foward, if it starts, its that part. the polls inside the ignition go bad, and that was my problem.
good luck!
Dwight
Old Oct 7, 2004 | 10:29 PM
Mr_CRX's Avatar
Default Re: Major starting problems (flawlessdjl)
I'm thinking it has to do with the wiring or the battery. My old d15 did this as well as my b18c.
Maybe i'm just telling myself its the battery so I have an excuse to buy one and relocate it.
Old Oct 8, 2004 | 04:48 AM
Origin's Avatar
Default Re: Major starting problems (Mr_CRX)
just what i was going to say, if it is your wiring its the perfect time to relocate your battery
Old Oct 8, 2004 | 10:46 AM
DieMaster's Avatar
Default Re: Major starting problems (Origin)
i love the input here guys
i might do custom wires. what gague wire shoud i use?
Old Oct 8, 2004 | 02:15 PM
DieMaster's Avatar
bump
what gague for the wires guys?
Old Oct 8, 2004 | 10:20 PM
Origin's Avatar
i used 1 0/T from the battery to a distribution block, then from there 4 gauge to the starter and the fuse box. just make sure to put yourself a inline fuse no further than 18 inches (if i remember right) from the battery. negative was the same size as my positive cable from the battery.
Old Oct 14, 2004 | 09:03 AM
DieMaster's Avatar
ok I redid my battery wires. here's the info:
4 gauge from - battery to chassy and from chassy to tranny
6 gauge from + batterty to starter
10 gauge from + battery to fusebox
i did all this and checked my ignition swich (cleaned it but was ok) and checked my shift position swich (also cleaned but was ok too)
so all are good componits
what do i do now?
Old Oct 14, 2004 | 09:16 AM
4drEF's Avatar
Keyboard Humorist
So if you take 12volts from the battery and hook it directly to the starter solenoid it starts? It that what you call the control wire?
If that's what you are doing then trace that wire back to the igntion switch and do an OHM test on it. Make sure the wire is in good shape. Maybe some spare wire to the solenoid to the pin on the igntion switch to test and make sure the stock wire itself isn't the culprit.
If all else fails, sell me the car for $5 and never have to worry about this ever again!
Old Oct 14, 2004 | 04:37 PM
DieMaster's Avatar
Default Re: Major starting problems (4drEF)
Yes the little BLK/WHT wire on the starter solonoid is the "control wire" i looked and has battery voltage when cranking and .5 volts not. when the ignition is on and i hook a wire from that termanal and touch it to + on batterty it starts right up. no clicking whatsoever
The wire from the ignition swich to the starter read just under 1 ohm. is that normal?
why would i sell ya my little baby my pride and need a wash joy
i will sell wa the car for 10 grand but it;s not worth that so never mind.
Old Oct 14, 2004 | 05:54 PM
DieMaster's Avatar
Bump plz help me
Old Oct 14, 2004 | 08:42 PM
DieMaster's Avatar
Plz this is realy bugging me
Old Oct 14, 2004 | 08:51 PM
doublethink's Avatar
when you turn the key to the crank position, the black white wire under the dash should read 12 volts
if it doesnt, then your ignitions swtich is bad.
if it does then the power just isnt getting to the starter, or you have a bad ground to the starter.
Old Oct 15, 2004 | 07:47 AM
DieMaster's Avatar
Default Re: Major starting problems (doublethink)
i know i have power going to the starter b/c it clicks and i re-did the grounds with costom wiring read above posts
Old Oct 15, 2004 | 08:32 AM
crx_88_si's Avatar
if your car is an 89+ check the clutch switch.
try disonnecting it and jumping the termins inside the plug ( the wire end of the plug). if it stops clicking all the time then thats the problem.
Old Oct 15, 2004 | 12:06 PM
DieMaster's Avatar
Default Re: (crx_88_si)
it's an automatic And i checked the shift pos. switch.
Old Oct 16, 2004 | 10:49 PM
DieMaster's Avatar
Default Re: (DieMaster)
come on this is realy getting to me
Old Oct 19, 2004 | 10:43 PM
DieMaster's Avatar
well i have tried evreything i can think of.
replaced battery NO
cleened ing. swich NO
cleened shift swich NO
cleened and tightened all coneters NO
replaced starter NO
replaced battery wires and engine / tranny grounds NO
checked evrey foot of wire accesssable NO
did other testing crap like volt drop test and amp test NO
i am at a total loss i dont know what to do
this is my daliy driver and i need it to go to work and school.
PLZ HELP ME
Old Oct 23, 2004 | 10:50 AM
DieMaster's Avatar
bump
JJT211
Jun 22, 2014 08:33 PM
seane51
Jan 17, 2014 03:50 PM
JDMB20TDA
Oct 2, 2008 08:38 PM
slywfbpsi
Feb 9, 2004 10:35 AM
00fbp
Jul 15, 2003 07:30 PM
