tranny leak passenger side, new gasket time?
Old Oct 6, 2004 | 06:07 PM
doublethink's Avatar
Default tranny leak passenger side, new gasket time?
i used brand new 90 teg axles and int shaft with a Y1 tranny, theres a severe leak on the passenger side, its really annoying.
could it be the gasket/seal?
Old Oct 6, 2004 | 07:31 PM
Default Re: tranny leak passenger side, new gasket time? (doublethink)
bump for my shitbox
Old Oct 6, 2004 | 07:57 PM
Dillbag's Avatar
-First of all it could just be a bad axle seal. the spring inside the seal lip could have popped out, or the seal lip could have a cut in it. fairly easy to change. but i'm not sure where you can get a seal, or if any usdm seals will work. Just ask/search around.
-Second: it could be that your axle/int. shaft/tranny combo is not quite right. meaning that if the axle or int shaft is the wrong length, the part of the axle that the seal rides on is not located where it should be. Or the part that the seal rides on is the wrong diameter due to axle/trans incompatability. uuhh, maybe.
It's been a while since I read up on axle tech, so i may be way off base. (i hope not) Check the hasport site's axle tech section, that should help.
Anyway, hope that helps, or at least gets you thinking in the right direction.
Old Oct 6, 2004 | 10:37 PM
Default Re: tranny leak passenger side, new gasket time? (Dillbag)
how flush should this thing be sitting?
Old Oct 8, 2004 | 10:37 AM
Dillbag's Avatar
HOW FLUSH SHOULD WHAT THING BE SITTING?
Old Oct 8, 2004 | 11:10 AM
Brownjd's Avatar
if it is just pouring out of the axle seal, then most likely its the bearings in the transmission. i've been thru 3 trannys because of that ****. first time it happened i thought it was the seal to, but 3 brand new seals and many curse words later, still leaking. and now my 3rd tranny is leaking to. only a matter of time till that bitch blows up to. hope this helps, and good luck.
Old Oct 8, 2004 | 01:33 PM
phan's Avatar
Default Re: tranny leak passenger side, new gasket time? (Brownjd)
are you sure the axle is in all the way? i've seen it happen before...the axle popping out while rebolting the knuckles, etc. tranny fluid leaks out just because the axle isn't in all the way. just an idea...
Old Oct 10, 2004 | 06:57 PM
Default Re: tranny leak passenger side, new gasket time? (phan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phan &raquo;</TD></TR><TR><TD CLASS="quote">are you sure the axle is in all the way? i've seen it happen before...the axle popping out while rebolting the knuckles, etc. tranny fluid leaks out just because the axle isn't in all the way. just an idea...</TD></TR></TABLE>
it stays in fine until its driven and turns are made. this really blows
itsLOUiSduh
Oct 17, 2008 12:31 PM
hectic57
Jun 18, 2008 02:49 PM
IT GUY
Aug 29, 2007 10:47 AM
civicjoe8
Apr 11, 2006 08:52 PM
Pele
Jul 31, 2003 06:32 AM
