Fabricating Tial Wastegate pipe
Old Oct 5, 2004 | 08:03 AM
00BoostedD16's Avatar
Default Fabricating Tial Wastegate pipe
What size pipe are you guys useing to make the pipe coming off a 38MM tial wastegate and where did you get it? I calculated 38MM's out to be 1.49" but i cannot find inch and a half mandrel bent pipe. Just let me know what you guyz are useing.
Thanks alot
Old Oct 5, 2004 | 08:09 AM
agrabau's Avatar
Default Re: Fabricating Tial Wastegate pipe (00BoostedD16)
vertexnow seller on ebay. Shoot them an email. They sell stainless 304 mandrel bends.
If you want JC Whitney also sells them.
Old Oct 5, 2004 | 08:19 AM
shearerfab's Avatar
Automotosports in Arlington can help you out. Give them a call.
http://www.automotosports.com
Old Oct 5, 2004 | 10:23 AM
Electron_LS-Vtec's Avatar
I get all my piping at Stainless works. They have anything you would ever want and they have good prices http://www.stainlessworks.net hope this helps
Old Oct 5, 2004 | 12:03 PM
Guys, thanks alot for your help, i will check out those sites.
Thanks again
Chuck
Old Oct 5, 2004 | 05:54 PM
Ekasey's Avatar
Default Re: (00BoostedD16)
You already got plenty of reply's but why not one more
We are expensive http://www.burnsstainless.com
Old Oct 5, 2004 | 07:08 PM
.dave's Avatar
i HAS questions ?
I bought a wastegate dump tube from Ben @ ImportParts, then went to Pep Boys and bought a bunch of 45 degree bends and clamps for now. It looks like ****, but didn't cost me more than $20. When I get my exhaust made I'll just have the guy make me a new dump tube.
Old Oct 5, 2004 | 10:51 PM
Thanks for the replies again. If anyone else comes across this just feel free to drop a site because it's nice to add more sites to my favorites.
Thanks Again
Chuck
Old Oct 6, 2004 | 01:31 PM
Doctor CorteZ's Avatar
Default Re: (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">
We are expensive http://www.burnsstainless.com</TD></TR></TABLE>
get what you pay for
Old Oct 6, 2004 | 05:11 PM
myprojectb13's Avatar
http://www.summitracing.com has 1.5" U bends for $9.95.
Old Oct 6, 2004 | 05:50 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Fabricating Tial Wastegate pipe (myprojectb13)
I made this from 1.5 inch Conduit piping that i bought from Home Depot for $1.99..
This was on my 46mm watsegate, but i made a similiar one thats on my 38mm right now..
Old Oct 6, 2004 | 11:14 PM
c jackson's Avatar
threes
Default Re: Fabricating Tial Wastegate pipe (SIXTYdashONE)
dont you think that angle is a little intense?
Old Oct 6, 2004 | 11:55 PM
PrecisionH23a's Avatar
I use the same **** that ron used. Ideally, you do not want such a sharp bend at the exit, but clearances for dump tubes are sometimes a bitch and require an angle like that.
I had a very similar angled dump tube like rons on my old set-up and there was no difference to be told between running the tube vs no tube.
Old Oct 7, 2004 | 02:30 AM
HT's Biggest Loser
Default Re: Fabricating Tial Wastegate pipe (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I use the same **** that ron used. Ideally, you do not want such a sharp bend at the exit, but clearances for dump tubes are sometimes a bitch and require an angle like that.
I had a very similar angled dump tube like rons on my old set-up and there was no difference to be told between running the tube vs no tube.</TD></TR></TABLE>
That was precisely my issue,ill post a pic up later of wht it was liek that.. Basiclly, i had to clear the radiator and dp .. it was tight
EDIT:. here ya go..
Modified by SIXTYdashONE at 6:56 AM 10/7/2004
Old Oct 7, 2004 | 09:27 AM
Guyz, Thanks alot for all the responces! Keep them coming! But how do you post pictures (I'm still somewhat new here)? I wanna show you guyz what i have to clear for my dump tube and see what you guyz think.
Old Oct 7, 2004 | 11:12 AM
accordfreak's Avatar
here was mine...
jcwhitney 1.5" U bend pipe for around 8-9 bucks.. 5 dollar flange from ebay....
I cut it up then had phil from spoolinperformance weld it for me.
Then I painted it black with bbq grill heat paint.
ramboPandA
Apr 12, 2016 08:42 AM
Scott53092
Mar 16, 2013 07:52 PM
HamiltonRex
Jan 30, 2006 06:15 PM
RACEPAK
May 22, 2004 01:04 PM
420aNT
Mar 8, 2003 10:15 PM
